916RWHP Straight Pump Gas..No Meth!!!
Remember this car?
![](http://img.photobucket.com/albums/v251/b20vtecek/DSC_0088.jpg)
We just got done putting it back together and did some tuning. We changed over to an A&A Bracket and belt slip was GONE. Look how solid boost is on the graph. This is on STRAIGHT pump as NO METH!!!
![](http://i121.photobucket.com/albums/o225/Frans402/Jordan912.jpg)
It made 916 in a later pull. I have video of a 904 pull. I will post it up shortly.
http://www.youtube.com/watch?v=olGzF...e=channel_page
It was an older style ECS bracket. It started slipping over 13psi. I just dont like the fact that you cant put your own tension on the belt. With A&A's it has a tensioner but you can also tighten a pulley then tighten the bolt and make the belt basically as tight as you want. This helped ALOT with the last few cars we have done.
Well i guess my questions is Do you think that A&A is better or similar to the procharger and why? You mentioned the ability to tighten ilder arm, etc it sounds similar. Just curious. lookin to upgrade to 8 or 10 rib setup
Moderator
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
You just missed a great deal on ths CF forum. Ecs used (less then 1k miles) 8 rib for 600 shipped.
Is your belt slipping? If your running under 9 psi then an 8-10 rib setup is over kill IMHO. If you plan to jack up the psi, then it should be your cup of tea...![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
