10.58@133.65mph Bolt on C6Z06 w/Monster Stage 3 clutch!
Well I took the car to Cecil county dragway today to see if I could get the car to hook a little better and get a new best. First pass the with the tires at 20psi the car bogged at a 3700rpm launch. I did a 1/8mi pass and shut it down. I came back up and did a 4000rpm launch and the car spun bad. I let the car cool down and tried adjusting the exhaust due to it was rattling on the driverside pretty bad. Came back up after some cool down and lowered the tire pressure to 18psi and with a 4000rpm launch the car spun again. I went back let the car cool down, dropped the tire pressure to 16psi hot. Launched the car at 3800rpm and the car pulled out with a little spin, the front end stayed up so I kept into it for a full pass. Heres the pass I was given....
60ft-1.631
330ft-4.512
1/8mi-6.876
1/8mph-105.41mph
1000ft-8.893
1/4mi-10.589
1/4mph-133.65mph
The best 1/8mph was 106.10mph so that was interesting. I cut a 1.57 60ft but I missed 2nd That would've been a low 10.5x or better pass. Then a mustang hit the wall (driver was ok)and then I called it a night. Theres definitely A LOT more in there and can't wait to get to test it out on a well prepped track and run it out more often. This clinches the #2 spot so I may give it a rest for a little bit then go to the track in December to put the #2 spot even further away for my Canadian sausage party Sebastl9x He promises that 2011 is going to be a fun year.... well until he finds out about my next few bolt on mods!
Pics for Proof
I'll post video later but regrettfully part way through the launch the video camera came loose and was just swinging so it pretty much makes you see sick.
I want to thank the following people/companies.
Monster Clutches for the clutch to help make it all happen.
RKT56.com for helping with the driveline,clutch setup etc.
Gary2004Z06 for being a good friend and helping make the driver and car work together.
Jeremy Formatto for the tune to give the power to make the ET/MPH's happen
My understanding and supportive wife
60ft-1.631
330ft-4.512
1/8mi-6.876
1/8mph-105.41mph
1000ft-8.893
1/4mi-10.589
1/4mph-133.65mph
Pics for Proof
Thank you for the compliments. Looking for 10.4's before the end of the year!!! Can still remove some more weight, better track prep, better 60fts, better shifting, electric waterpump and she will be FLYING!!!
Just some thoughts of 1.55 60ft or better would take approx .10 off. Thats a 10.49 with everything being the same. Then take into account some more weight out, electric waterpump and better driving, better weather/-DA..... do we dare think of the improbable? 10 POINTTTTT????? HMMMM!
