Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
c6 engine removal
Old Jan 3, 2011 | 02:29 PM
dhpewterz's Avatar
Default c6 engine removal
Is their a good write up anywhere I can look at? Im used to pulling fbody motors and im not up to par on pulling out of a corvettes. Ive searched everywhere and cant find nothing. Im looking for tips or tricks. I assume out the bottom will be the easiest? I do have a lift. Any help would be appreciated.
Thanks
Darren
Old Jan 3, 2011 | 05:19 PM
BlownVette 2001's Avatar
Not sure if you have an auto or six speed ?
Auto's are easier to do, because it's easier to line up the spline shaft for the torque tube.
Basically, disconnect the battery, drain all of the fluids.
Pull out the radiator and fan assembly. If you're going to drop it out the bottom, disconnect the shocks front spring and upper control arms.
Pull off the calipers and hang them on the sides with some coat hangers or wires.
Disconnect the engine harness, PS, brake lines, etc ...
If you're using a two post lift make sure you put a few jacks around the car to make sure you don't accidently knock it off the lift.
Here's a good site that was for C5's. Basically the same for the C6's.
http://www.cajundude.com/engineswap.htm
Old Jan 3, 2011 | 07:26 PM
4DRUSH's Avatar
Piece of cake with a lift
A little eye candy
Old Jan 3, 2011 | 08:53 PM
Stang's Bane's Avatar
Are those tfs cathedral or square port heads?
Clean anyway you look at it...
Old Jan 3, 2011 | 09:42 PM
4DRUSH's Avatar
Cathedral
Old Jan 4, 2011 | 07:40 AM
Nice stuff there 4DRUSH.
What's the height of your ceiling in the garage ?
Old Jan 4, 2011 | 06:25 PM
4DRUSH's Avatar
Thanks
Ceiling is 11' 2"
Old Jan 4, 2011 | 06:46 PM
Originally Posted by 4DRUSH
Thanks
Ceiling is 11' 2"
Thanks, next house will have a taller ceiling. Current township won't allow me to add another garage.
Wanted to put in another set of garages with 12ft ceiling so that I could put a 4 post and a 2 post lift in it.
The 2 post are great for dropping motors and I like the (4) post for doing brake, suspension and other under the car stuff.
That's a great set-up that you have.
Old Jan 4, 2011 | 07:15 PM
4DRUSH's Avatar
Does your garage have living space above?
If not, a flat ceiling can be made cathredal and possibly provide enough height in the center for a lift.
Old Jan 5, 2011 | 09:17 AM
I have a cathedral ceiling, but it's part of the living space. My township is a PIA about doing certain modifications and frankly after years of debates with them over everything, it's just easier to sell and go somewhere else.
