Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Help Grinding Noise
Old Jul 1, 2011 | 08:41 PM
Midnight00SS's Avatar
Default Help Grinding Noise
I have a 99 C5 and noticed tonite when I went to back out of my driveway in reverse and let off the clutch it made a grinding noise from the tranny, then noticed it does it in first when taking off too, and sometimes when ur going thru the gears normally driving u can hear it also, car was fine before this, I have about 55k on it, any ideas? Clutch or trans shot?
Old Jul 1, 2011 | 08:58 PM
silverbullitLS1's Avatar
I have never had that problem, but if it drives fine it might be your throw out bearing. Just my 2cents
Old Jul 2, 2011 | 11:55 AM
Yea drives fine, I'm probably just gonna do the clutch while I'm at it rite?
Old Jul 3, 2011 | 07:10 AM
c6r's Avatar
c6r
Grinding while your shifting or just moving forward? Check and make sure your trans/diff oil levels or full also? good luck
Old Jul 3, 2011 | 10:04 AM
4DRUSH's Avatar
Definitely, plus headers, and a supercharger.
Old Jul 3, 2011 | 10:13 AM
I can have the car in neutral and step on the clutch and as soon as i let it up it makes that grinding noise
gonna check the oils
Old Jul 3, 2011 | 08:22 PM
pozesd99''s Avatar
Sounds like a hydraulic problem which are common. Master cylinder, slave cylinder and throw out bearing
Old Jul 4, 2011 | 09:29 AM
Yea gonna do the clutch and slave while im in there
