Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
C5 z06
Old Sep 19, 2012 | 09:25 AM
Lowmiles's Avatar
Default C5 z06
I recently purchased an 02 c5 z06. I went run the car (after owning it for a day) i ran a 12.8 @ 114 on the original eagle f1s 30psi with a borla cat back. Air was in the 80s and very humid southern LA. Since then i have done a set of headers x-pipe, vararam intake, and tune. I will run the car again soon on some nt05rs. Was wondering what i should expect from the car now.
Also do other c5 z06 owners notice that the front seems to have an excess amount of brake dust on the front wheels. I understand that there will be more than normal, but my wheels are almost black.
Old Sep 19, 2012 | 02:39 PM
stevo92z28's Avatar
All depends on launch. Assuming you can get into the 1.9-2.0 range on street tires 11 seconds will be possible. See sig to see what it's capable with mineshaft air and a good set of tires .
Fronts will leave dust after a short drive, that's normal. They came with good pads, which will leave brake dust.
Also i will add that with more power it can be more difficult to effectively put it to the ground without spinning, i'd suggest a drag radial to avoid any wheel hop that sometimes occurs with street tires.
Old Sep 19, 2012 | 02:47 PM
pittman's Avatar
I will guess a 12.1 @ 117 in this hot air.
Old Sep 19, 2012 | 05:36 PM
Lowmiles's Avatar
Car will have nitto nt05rs the next time i run it so that should help the traction issue a lot.
Old Sep 19, 2012 | 08:14 PM
thepitstop2010's Avatar
12.30@116 mph would be my guess. I've learned not to set high expectations that way there's no disappointment.
Old Sep 19, 2012 | 09:20 PM
TransAmcoupe98's Avatar
thats a good run honestly in that DA.
Old Sep 20, 2012 | 09:38 AM
Lowmiles's Avatar
I'm hoping for 12.1s 12.2s, which i know is very possible. I went 12.8 @ 113 on street tires in my bolt ons fbody in the cold air. So with tires on the vette i think its very possible i can get low 12s out of it.
Old Sep 20, 2012 | 11:36 AM
Alex41's Avatar
My friend had a stock with batwing filter 03Z a while back. We took it to the track at Gulfport MS one summer night on some 18" bfg's. I had never driven a vette before, let alone tried to race one but I turned a 12.4 and he was able to get a 12.1 out of it before the night was over.
The tires will help but the biggest thing is knowing how to drive your car on the track. If I remember correctly, we left at about 3K and slipped the clutch out as opposed to straight dumping it. Don't try to no-lift-shift it, vettes don't like that with the trans in the back and linkage to the shifter. Bad mojo happened to another friend of mine trying.
Good luck and post the results. Congrats on a vette fellow z owner.
Old Sep 20, 2012 | 04:15 PM
Lowmiles's Avatar
I had never driven a vette aside from my dads C6 so that was a big factor, and the tires just plain suck, it broke loose on the hwy at 60 yesterday. I didnt want to launch it hard and have never tried no lift shifting anything. But i feel im getting better with the car. The 12.8 run was my 2nd run an my first was a 12.9. The tires are so old i didnt want to test my luck and have one blow out at 100 mph and total my new car. I have drag radials and a good set of front tires on the way. And im hoping the weather will cool off before the next time i run it.
Old Sep 21, 2012 | 09:05 PM
ajrothm's Avatar
My 02 Z06 went 12.16@117 with a 1.74 60'. Completely stock other then BFG drag radials. I don't recall the DA, it was an average Fall night, maybe +1000'. This was the first time out in the car. I wouldn't even try to run on the stock tires. I by far am not that great a driver either.
Old Sep 22, 2012 | 07:14 AM
WKMCD's Avatar
If you're not running road courses, I found the Carbotech 1521 brake pads to be excellent with very little dust. What dust there is is pale gray and non-corrosive so it doesn't tear up your wheels. Braking is excellent!
Old Sep 22, 2012 | 07:39 AM
Lowmiles's Avatar
I saw those, im thinking of doing the c6 brake upgrade. If not ill probly just buy a good set of ceramic pads
Old Oct 1, 2012 | 03:15 PM
Amp'd Adam's Avatar
I agree the Carbotech 1521 compound would work well for you. Let me know if I can help you.
The Carbotech™ 1521™ is our high performance street compound. The 1521™ compound is known for its release and modulation, along with unmatched rotor friendliness. 1521™ is also a very low dusting and low noise compound with an excellent initial bite. This compound's excellent linear torque production provides incredible braking force without ABS intervention. Carbotech™ 1521™ operating range starts out at ambient and goes up to 800°F (426°C+). 1521™ is suitable for ALL street cars, perfect for your tow vehicle or fleet vehicle. Carbotech™ 1521™ is NOT recommended for ANY track use.
F $148 R $128 Less 5%.
