Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Torque Tube for Dummies
Old Feb 18, 2013 | 08:19 PM
jaxeagle's Avatar
Default Torque Tube for Dummies
Just trying to understand. Please add or correct me if I am wrong.
Upgrading the Torque Tube on my C5 will not add power as measured by the dyno but it will help get the existing power to the ground and thereby add "seat of your pants" or realized power.
Old Feb 18, 2013 | 09:23 PM
garygnu's Avatar
is a after market torque tube stiffer ?
Old Feb 18, 2013 | 09:45 PM
jaxeagle's Avatar
I dont know but I'd guess maybe stiffer transfers power more efficiently
Old Feb 18, 2013 | 11:39 PM
2000PewterT/A's Avatar
Upgrading the rubber bushings/biscuits with billet ones is a popular upgrade I have heard of before. Less driveline flex and more power to the ground. As for upgrading the entire tube I am not sure if anyone does that or not.
Old Feb 19, 2013 | 09:07 PM
jaxeagle's Avatar
That makes sense as well. Probably cleaner and cheaper than replacing the whole thing. It was my understanding that there are upgrades to the entire tube.
Old Feb 19, 2013 | 10:04 PM
V-seriesTech's Avatar
The factory torque tube has two composite bushings, with metal inserts...joined by bolts..6 on top, 6 on bottom(front/rear).. over time and street use...they start to deteriorate. Sometimes, pieces can actually go through the aluminum housing of the torque tube. Sometimes, these pieces can actually cause the bolts that held them together to bind/fold over and snap or shear. I have had the couplers go bad....and I have also sheared bolts inside the torque tube, on the driveshaft, with good couplers(got torque?).
Anywho...here's a couple pics of what can happen to stock ones.....
left overs..
...and the upgrade(badass aftermarket COMPOSITE couplers are available instead of the solid billet pieces that I run).
A complete torque tube....
Mounted to trans/engine.
Old Feb 20, 2013 | 09:23 PM
jaxeagle's Avatar
That helps A LOT!! So a key piece in not having as much lost power from fly wheel to ground, correct?
Old Feb 21, 2013 | 02:09 AM
RonSSNova's Avatar
So you mean get the power to the ground quicker? I doubt you could measure the difference.
You should ask this on the Corvette forum.
Old Feb 21, 2013 | 07:35 AM
Blackpanther99's Avatar
Correct.
Old Feb 22, 2013 | 07:24 AM
Whistler's Avatar
Sawzall and Welder Mod
Upgrading your torque tube will do nothing for power , either seat of the pants or dyno, or MPH at the track. What it will do is withstand a higher level of torque before failing.
Old Mar 11, 2013 | 07:41 PM
jaxeagle's Avatar
No seat of the pants huh, won't deliver the power any more efficiently or at least not enough of a difference to feel seat of the pants? Ok, thank you for the reply!!
