Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Dyno results for 04 C5 6speed (Non Z06)
Old 07-20-2004 | 12:35 PM
Qwik03's Avatar
Livin La Vida Goat
Default Dyno results for 04 C5 6speed (Non Z06)
I just got done running my 100% stock 04 C5 on the dyno.
Car has 450 miles on it and the run was done on a dynojet in 86 degree weather.
rwhp 317.65
rwtq 335.34
Seems like a decent starting point.(My 00 SS baselined at 303/315
I will be adding a Magnaflow Catback with X pipe and the Zip tie mod within the next couple of weeks.(I will post my results accordingly)
Brandin
04 C5-stock(???)
03 Silverado-sold(14.5@95)-boltons
00 Camaro SS-sold(12.1@116.5)Boltons and TR224
Old 07-20-2004 | 01:02 PM
Colonel's Avatar
"I will be adding a Magnaflow Catback with X pipe and the Zip tie mod within the next couple of weeks.(I will post my results accordingly)"
Cool. Plan to do any before and after track runs?
Old 07-20-2004 | 01:46 PM
Qwik03's Avatar
Livin La Vida Goat
Colonel,
I always try to baseline my car before I start modding it.(Dyno/Track)
I think we are in the same state of mind when it comes to our C5's.I want to keep the car intact and enjoy it for as long as possible.(While modding it for daily driver status)
I made the mistake of turning my 30K Camaro into a drag car and destroyed it within 35K miles.(Motor,tranny,rear,interior)I will not make that mistake again.
I love this car, it is everything I wanted my SS to be and then some.
2 of our local tracks are closing within the next 2 months and I am over driving 2 hours for 2 runs.
Future plans call for exhaust,intake,ported TB,100 dry shot along with a slightly lowerd stance and hopefully some HRE's if things work out.
I just want a comfortable car that can suprise some people when the time calls
What do M6 Vettes typically dyno stock?
Brandin
Old 07-20-2004 | 02:17 PM
C5 CU's Avatar
interesting item on "new" C5 dynos, they appear to have a little higher rwhp after about 1500 miles...so your car at around 2000 miles would probably dyno 5 to 10 rwhp higher than at 450 miles...sometimes this fact can be misleading after adding a mod, thinking the mod contributed more than it actually did....
i have been told (read on Forum?) that GM tuning "adjust" after breakin miles or around 1500 - 2000 miles...not based on fact, just Forum gossip?
Old 07-20-2004 | 03:49 PM
Qwik03's Avatar
Livin La Vida Goat
I actually just pulled the car again after it sat while I ate lunch.
I work at a facility that has 2 dynos and the air quality was poor in the room this morning due to the other dyno being used.
I started it up and let it run until it was up to temp.
New numbers:
rwhp 317.65
rwtq 337.63
All runs are SAE corrected and there is no mods or dyno tricks.
I wonder if it will hit 365 rwhp if I keep running it!
Old 07-20-2004 | 05:05 PM
VINCE's Avatar
Shorty Director
I remember my bone stock 01 SS putting down 318rwhp/329rwtq with 1000 miles on her. I wonder what my 99 FRC with almost 60k would put down
Old 07-20-2004 | 05:23 PM
Qwik03's Avatar
Livin La Vida Goat
Vince,
Alot less than it will with that 408 stroker!
Screw baselines!
Old 07-22-2004 | 05:31 PM
770Guy's Avatar
I thought you had a camaro vince, when did you sell it?
Old 07-22-2004 | 05:53 PM
VINCE's Avatar
Shorty Director
I do have a Camaro. Atleast until the insurance company buys it from me.
Old 07-23-2004 | 08:31 PM
Slowhawk's Avatar
LS1Tech Sponsor
Those #'s are exactly what I got when it was stock.The air box removal added a bit,but the car really woke up with some tuning.
Old 07-26-2004 | 01:38 PM
ArmyVette's Avatar
Just had my 04 coupe dyno'ed and tuned last week on a Dynotech dyno.
Came in at 290 rwhp and about 315 rwtq (if I remember correctly). I thought this was a little low.
Have a 3.42 gearbox, 2800 torque convertor, and Vararam VR-1B installed.
Do these numbers sound a little low or is this what I should expect?
(Had the car baselined at another dyno before the mods were installed and it produced 306 hp.)
Old 07-26-2004 | 01:58 PM
Qwik03's Avatar
Livin La Vida Goat
I have never heard of a Dynotech Dyno?(Maybe they read lower like a mustang dyno)
Did you do a baseline before the Tuning and intake were installed?
You would probablly be better off running it again at the first place you had the coupe dynoed.
I would guess that an intake and tuning would give you close to 20rwhp+
Remember the Vararam will show much better track times then dyno due to the ram air effect.
I also think the gears and converter are costing you some power.On the dyno it is less efficent but on the street it feels gooooood!!!
Sounds like a beautiful car!
Brandin
Old 07-26-2004 | 07:52 PM
ArmyVette's Avatar
Qwik03, if that's for me, yeah, I had a stock baseline with just the Vararam system installed. Wasn't happy with the original place that did the baseline tune and took it to another place that finished the tuning.
The dyno shop I finally used was awesome. I'll post the link here tomorrow of the equipment they used (the link's on my office computer ). Anyway, the tuner said his dyno is about 10-15 HP lower than most other brands but that you definitely lose HP adding drivetrain components without adding engine components to make up the difference. As was stated in posts above, 10-15 HP loss isn't unusual going from 2.73 gears to 3.42 gears. Can you imagine if I'd gone directly to a 4.10?
EDIT: Remember the site: www.dynojet.com
The car's performing great now that the tune is done. The tuner said my new Vigilante TC might be slipping a little. I need to run by my local Vette garage and have the guy check the tranny fluid level -- these trannies are so sensitive to being even a LITTLE bit low of fluid.
Thanks for the interest!!!
Old 08-09-2004 | 06:37 PM
xp3nd4bl3's Avatar
Moderator
Brandin, you failed to mention that you'll be putting a cam in. What gives?
Old 08-10-2004 | 11:03 AM
Qwik03's Avatar
Livin La Vida Goat
boltons only for this car!
intake
exhaust
shifter
nitrous
supercharger
etc...
valvecovers are staying on until I hit the motherload like you
Quick Reply: Dyno results for 04 C5 6speed (Non Z06)
