steering lock recall
whats up guys, i took my 2000 vette in for the recall, what exactly were they suppose to do? it still locks when i take the key out. i was under the impression that they eliminated that. thanks in advance, mitch.
The recall is a bunch of crap (for the MN6). If you weren’t having a problem with the lock all they did was reprogram the ECM to make sure the car won’t run (the fuel is cut off) when the wheel is locked. In some years the program would allow the car to keep running if the lock malfunctioned and locked up. My car did this. I started the car but the lock did not unlock. Luckily I noticed this before I moved. Even if they replace a defective lock assembly, it will go bad again.
For automatic Vettes they disable the lock. This actually does fix the problem.
For MN6 cars the best thing to do is to get the CLB (column lock bypass). Sooner or later your column lock will malfunction and leave you stranded if you don’t have the CLB.
The recall had been done last October and now the car has the "service cullom lock" coming on.The car runs fine but when you tap the axcelerator...the car stalls because the fuel get's cut off.It will start up but will cut the fuel if I touch the axcelerator
I'm not sure the CLB will work for me.Does anyone think it will cure the problem I'm having?.
![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
The CLB will not work on a car that is experiencing a column lock malfunction. The CLB must be installed while the lock is in proper working condition.
There is a resistor they also install. It is black and if you take off the knee bolster under the steering wheel you should be able to see it. The problem with it is current levels, so it will cause the Column Lock to come on... If you take it out, and plug the harness back together your car should be back to normal. If it is an auto, they are suppose to remove the lock so it won't lock ever again anyways... The resistor is a pos...
I'll try that to see if that's the problem.I just got the car back home a few minutes ago because the deal would not fix it under the recall.They told me they want to replace the whole steering lock because the computer is telling the car the lock is on.They said it's not working correctly and need to be replaced.The steering lock doesnt even work when the key is removed.
If it has already had the recall done, this is probably the problem... Take off the knee bolster, and look around for a black box (might have foam wrapped around it...) There is a silver metal piece that supports the steering column, it might be sat on top of it... (depending on where the technician put it..) It is a black resistor box, and you should be able to follow the wires from each side... Remove it and plug the wires back in together.. PM me if you have any questions...
You can if you have LS1 Edit programed.I have LS1 edit on my 94 RX7/LS1 but not on the 98 vette.I cant swap PCM's cause the motor I have in the RX7 is a 01 and no PCM can be interchangable with a 98.Car is still no running.
![Cry](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cry.gif)
Originally Posted by PA Z06
Can you just detail the lock with LS1 edit ?
You can if you have LS1 Edit programed.I have LS1 edit on my 94 RX7/LS1 but not on the 98 vette.I cant swap PCM's cause the motor I have in the RX7 is a 01 and no PCM can be interchangable with a 98.Car is still no running. ![Cry](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cry.gif)
