Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Help with Head/Cam Mods ...
Old Aug 30, 2005 | 04:39 PM
SCEMO's Avatar
Default Help with Head/Cam Mods ...
I would like as many suggestions as I can get on further modifing my '04 Z06. Currently I have an MTI G1 cam with Kooks headers with hi-flow cats. Unfortunately the power isn't there and I want more. My question is ... what is the best heads/cam set up that will not only generate the most power, but be relatively safe on my daily driver. Thanks in advance guys!
Old Aug 30, 2005 | 06:07 PM
PA Z06's Avatar
I hear alot if goods things about 205 AFR Heads
Old Aug 30, 2005 | 06:29 PM
baldurann's Avatar
AFR's and a cam (around the same size as you have now, why go smaller?) that matches the characteristics of the heads. Then it's on to the smaller things... Electric Water Pump, FAST 90/90, Cutout, ASP pulley, etc.
... All of this, assuming you want to stay N/A and not go the N20 route.
Old Aug 30, 2005 | 10:32 PM
pdd's Avatar
pdd
search and more search
Old Aug 30, 2005 | 10:35 PM
Assassin's Avatar
do you want to go FI
Old Aug 30, 2005 | 10:56 PM
SCEMO's Avatar
Was thinking about ...
ET performance Heads ... 225 or 215 cc
Cam Specs... 236/244 .609/.629 on a 112 or 114.
Old Aug 30, 2005 | 11:32 PM
platinum's Avatar
i am going with 225 afr heads with 224/228 581/588 115 lsa. i am also running a maggie with a 2.6 inch pully and nos
Old Aug 31, 2005 | 09:13 AM
JustLucky's Avatar
SCEMO, I see that you live in Houston and that you have a MTI G1 cam. Personally, I would recommend going by or calling MTI in Houston for a nice package deal. After long and careful research I chose MTI to work on both of my LSX powered cars and I would not go anywhere else. MTI has great parts, great people, and great service. They have a newer cam profile out that will net better gains than your current G1 and their heads are top notch along with their head/cam deals.
As far as other mods I would suggest a Vararam or MTI intake, high-flow airbridge, FAST 90/90 setup or just get a P/P TB, BB Triflo or Corsa Catback, and 4.10 gears w/ hardened output shafts. You already have a really nice set of headers and high-flow cats. Oh and a good quality dyno-tune from MTI. Good luck and I hope I helped some.
Old Sep 3, 2005 | 10:02 AM
eamador11's Avatar
The best h/c package now is AFR 205s and G5x3 cam
Old Sep 3, 2005 | 10:26 AM
30th t/a's Avatar
you read my mind. milled afrs 205/ g5x3/lsx90mm = proving setup= 470rwhp+
Old Sep 3, 2005 | 11:52 AM
NOSjohn's Avatar
Restricted User
If you're not happy now with the current Cam and Exhaust setup, I doubt you'll be happy with a little bit better cam and heads. I would guess now you're pushing 400-420 rwhp and better heads/cam may only net you ~30-40rwhp...with a good tune.
I'm just trying to analyze your situation as it doesn't sound like you may be happy with another 30 - 40 at the wheels...and that's pushing it. You may have to go juice or hairdryer to get that power rush you may be seeking.
I guess a better place to start is: what power level do you think you'll be happy with?
...then go from there.
