Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
What gears should I go with
Old Sep 1, 2005 | 06:42 PM
00Vette's Avatar
Default What gears should I go with
I got a 2000 C5 with roughly 450whp and I will put 150 dry shot on it next year sometime. I'm getting a heavy duty rear diff. installed and I was thinking of going with either 3:73's or 3:90's. What would you guys chose and why? Thanks.........
Old Sep 1, 2005 | 08:20 PM
C6.Z51's Avatar
Definently get some 4.10s. Especially for straight line performance. Quater mile times will drop about 3 or 4 tenths. Nuff Said.
Old Sep 2, 2005 | 05:37 AM
XTrooper's Avatar
A4 or M6 tranny?
If you have an A4, get 3.73 gears. If you have an M6, get the 4.10's.
Old Sep 2, 2005 | 10:22 AM
00Vette's Avatar
Its an M6
Old Sep 2, 2005 | 10:41 AM
NOSjohn's Avatar
Restricted User
Get the 4.10's if you're mainly concerned about 1/4 mile times. It should drop you a few tenths on just gears alone. You won't suffer drivability as there is much room for cruising in 5th or 6th gear.
Old Sep 2, 2005 | 03:53 PM
00Vette's Avatar
Thanks. I'm gonna go with the 4:10's. I appreciate everyones inputs.
Old Sep 2, 2005 | 04:57 PM
JustLucky's Avatar
"If you have an A4, get 3.73 gears. If you have an M6, get the 4.10's."
-XTrooper
"Get the 4.10's if you're mainly concerned about 1/4 mile times. It should drop you a few tenths on just gears alone. You won't suffer drivability as there is much room for cruising in 5th or 6th gear."
-NOSjohn
I agree with them. If your car is an M6 then definitely get the 4.10's. A buddy of mine had the 3.90's in his '02 Z06 and then switched them for the 4.10's and he is a lot happier with the 4.10's in the rear, and he performs better at the track now, and he didn't notice much of a drop in MPG on the highway either. Good Luck.
Old Sep 3, 2005 | 12:13 PM
slt200mph's Avatar
Good choice..you will not regret it...
Old Sep 4, 2005 | 03:30 PM
MagikMan's Avatar
w/ 4.10's do you have to go into fifth in the 1/4
Old Sep 4, 2005 | 04:33 PM
BonerBen's Avatar
4.10's might be a handful with that car unless you are running on 28" slicks.
Old Sep 5, 2005 | 07:12 AM
EPP's Avatar
EPP
As the power level goes up, so does your mph in the 1/4 mile, which means your car is taching higher as well. Unless you are prepared to run 28" tall tires on the rear and drive through the traps at 6800 to 7000 rpm, you may want to reconsider your choice of rear gears. With over 500 rwhp I would suggest the 3:73 gears if you want to be trapping at 6200 to 6500 rpm. Bob
Old Sep 5, 2005 | 07:30 AM
Soldiernurse's Avatar
Formerly MagRedC5
Its an M6
Find other C5 Enthusiast w/similar mods to yours w/3.73 or 4.10 for comments. In otherwords, go to Corvette Forum C5 Tech section to ask same question, as well as look mods listed in CF members sigs ... just a thought. Since I have an A4 my 3.42 [replaced 2.73] preference is not applicable to your situation.
