Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Sleeper Z06 plans, time to mess with some cobras
Old Oct 30, 2005 | 06:12 AM
  #41
baldurann's Avatar
Originally Posted by 2MuchRiceMakesMeSick
A painted fast intake wont look stock. It says fast right on the top/front of the intake.
You could always sand it off.
Old Oct 31, 2005 | 08:58 AM
  #42
Worm's Avatar
Originally Posted by Var
he wants to cheat people out of money
Doesn't everyone?
Old Oct 31, 2005 | 02:49 PM
  #43
Var's Avatar
Var
I would if i could.
Old Oct 31, 2005 | 09:26 PM
  #44
TT_Vert's Avatar
Originally Posted by SDC
Yeah I'm popping the hood $$ racing EVERYTHING has to LOOK stock. So no headers. I think a cheaTR cam, ported TB, pulley and a good tune would get me to atleast 390rwhp. Rockers is a great idea, if I decide to keep the stock cam, also I haven't thought of thanks!
the cheatr can will NOT sound 100% stock, it will have some lope that anyone will detect. I've done the exact same thing you are wanting to do and my car runs quite well despite almost being 3500# now (due to dynamat). I have an 00 C5 Vert w/ z06 manifolds, h pipe and a 2000 cat back. Car is dead silent but at idle is has a very slight lope to it you can and will notice. I tried to up the idle some to 900 and it just sounds like the car is racing a bit and people will suspect something. My car looks 100% stock and is well into the 11s w/ an ls1 intake still and ls6 exhaust manifolds (Same as ls1 anyway)
Dave
Old Oct 31, 2005 | 11:06 PM
  #45
KB99WS6's Avatar
hmm, sounds like maybe the only choice is an LPE GT2-3. I'm pretty sure that has no lope to it.
Old Nov 3, 2005 | 03:53 PM
  #46
Worm's Avatar
**** it, LPEGT2-3, 125 Dry shot. Bring the cobras Should run 130mph in the quarter.
Old Nov 3, 2005 | 05:25 PM
  #47
KB99WS6's Avatar
Sounds like a plan, just keep in mind that GT2-3 will only gain you about 10rwhp on your 02 Z06. Even Ed @ LPE said this, so it might not be worth the expense if you are going to do N20 anyway. If you are buying new and having a shop doing the install, not sure if you could justify the expense for 10hp, but if you will do the work yourself, maybe its worth it to you. Also, I heard someone say that the 02+ Z06 cams like N20....not sure why, but thats what I heard...
Old Nov 3, 2005 | 11:32 PM
  #48
seayzo6's Avatar
This should solve all of your sleeper needs. They won't know what hit them. Click on the link, scroll down until you see the Money Maker Intake.
Quote:
This is our hidden system(AKA Money Maker intake manifold). It is adjustable 35-300hp
Cost 800.00
https://ls1tech.com/forums/showthrea...ht=money+maker
All these systems come complete with 10lb bottles, all fittings and parts.Anything custom is possible. System can be changed to fit your needs..
Nitro Dave's Performance & Nitrous Outlet
Old Nov 4, 2005 | 04:48 PM
  #49
Dean-o's Avatar
One solution would be to get a cam under .550 lift and you can use stock 02+ Z06 springs. LPE actually sells the GT2-3 WITH 02+ Z06 springs and says they have had no problems even though I believe that cam is .575 or greater.
Jessel roller rockers will go along way towards keeping the valve train noise down and will allow you to turn more rpms.
Old Nov 5, 2005 | 07:08 PM
  #50
Robert56's Avatar
A Vararam and 315 BFGs got my time below, and self tuned. Blows away all the Cobras around hear. Then if someone has a highly modded Kenne Bell Cobra or something similar, it's time for one stage, two stages or throw the thrid stage of n2o in the mix. Stock cobras are slugs compared to the Z06, so maybe some more seat time is all you need. If your going up against a highly modded Cobra, why can't you be modded. You cheat someone on purpose in my area and you'll get what's coming to ya, for sure. If you have to cheat, stay the hell home with your mother.
Robert
Old Nov 6, 2005 | 09:54 AM
  #51
KB99WS6's Avatar
Hey Robert, I just bought a Vararam for my 01' Z. Did you have to get the car tuned after adding the vram? What type of gains did the Vram give you? Also, when you say 315's do you use 17's at the track, or is that 315's on the stock Z06 18's? What are they like 315/30's??
PS-I am "kbreese" over on the corvette forum.
Old Nov 6, 2005 | 12:47 PM
  #52
Chicago Crew UnderBoss's Avatar
VARARAM, One of MTIs killer STEALTH CAMS, Long Tube Headers, and some 315 BFG DRAGS and Fruckin FUGHATABOUDIT!!!!!!!
Old Nov 7, 2005 | 02:02 AM
  #53
Robert56's Avatar
No in the beginning I just let the computer do a relearn. Your long term fuel trims can compansate upto about 25% lean or rich. But for ultimate performance you will need to tune your ltft and MAF. The reason being is with the Vararam you'll see postive ltft, meaning computer is adding fuel for a lean condition (Vararam is flowing more air) which is ok, computer is taking car of it, except when going WOT. At wot the computer freezes positive ltft (say 10/15%) and adds this additional fuel to your WOT Power Enrichment Multipier, so you end up running pretty rich at full throttle only, killing some power. If your ltft is in the neg percent they are dropped at wot. This is why when tunning ltft we try to get them in the neg area a bit, then thay have no effect on wot performance. the gains are the time in my sig for stock CAI/DR after a self tune.
I run the 315 30 18 BFG on stock Z06 10.5 wheels, new style. Old style you can get in 315 35 17 and tread compound is similar.
Old Nov 7, 2005 | 07:14 AM
  #54
KB99WS6's Avatar
So even after the computer relearns the addition of the vram, it will still run very rich at WOT? So essentially the car could actually run slower with the addition of the vram and not getting a tune, ever after the computer relearns?
Where I am at is I have a vram right now, and plan on getting LT's eventually but not sure when that will be. Might not be till spring. I don't want to pay for a dyno tune until I get the LT's on, b/c I don't want to pay twice. So I am wondering if its even worth it to put the vram on now.
Old Nov 7, 2005 | 07:34 AM
  #55
CarsRFun's Avatar
get gears and nittos.. they will impove your 1/4 more than the above mods.
Old Nov 7, 2005 | 10:26 AM
  #56
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
AFR 205s with the logo milled off.
FAST 90 sanded and painted black.
GM90MM TB
Stealth cam of your choice.
HP would be in the 410-415RWHP range... Maybe as high as 420.
Old Nov 7, 2005 | 02:08 PM
  #57
Robert56's Avatar
No it won't run slower, you will see gains, however, for optimum performance a re-tune is in order. yes, it will be a little richer at wot throttle, but gains will be there. I would put it on and then wait for LT for a dyno tune. Some see lean codes at first, but just reset, and after 100/200 miles computer will make adjustments as far as it can. I never threw a code, mostly it seems to be the '04's which came wwith a slightly leaner tune than previous years.
Robert
Old Nov 29, 2005 | 01:14 AM
  #58
Somebody09's Avatar
I'm going to make my firebird a sleeper with Nitro Dave's "Money Maker." Maybe, if you don't mind a hidden direct port nitrous system, you'll do the same?
-somebody
P.S. I have no idea how I found this thread.
Old Nov 30, 2005 | 07:12 PM
  #59
Steve01SS's Avatar
I gave up on the sleeper thing with my car.. but you can do it.. and then throw some juice on it afterwards... hehe
Old Nov 30, 2005 | 08:24 PM
  #60
Dales396lt4's Avatar
I have done many bone stock Zo6's with a small dry shot of gas (125hp) and 275/40/17 ET Streets on Z06 Front rims sleeper and this is how you do it Stock they ran 12.2 and made 354 rwhp flip the switch and you have 454 rwhp 11.10 @126 1.7 60"... I have made a lot money on these Vettes. Look, sound and run bone stock ha ha flip the switch and take the money!
