Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
spark plug gap
Old Jan 31, 2006 | 02:50 PM
c5_ls1_6spd's Avatar
Default spark plug gap
im getting a set of ngk tr55s for my '02 c5 ls1, what should the plug gap be for the best performance?
Old Jan 31, 2006 | 03:25 PM
whitecamaross's Avatar
dont make that mistake and stay with stock plugs. i bought the tr55s and i didnt like how my car felt with them. i dumped them after one week of use and bought ac delcos which is what my car had and it is a world of difference.
the tr55's are gapped at .55 and the stock ones are gapped at .41 so you are actually putting a much much colder plug which will hurt your n/a engine performance...
i wasted my money on ngks and i will never put them again..
Old Jan 31, 2006 | 03:27 PM
HolyShiznit's Avatar
^^^ True, although it won't show up on the dyno very much.
Get colder for nitrous and such, otherwise don't change it.
Old Jan 31, 2006 | 05:35 PM
what's the best plug to get for N/A performance and what should the gap be?
Old Jan 31, 2006 | 07:36 PM
i just told you they are the ac delco iridium plugs..thats what my 04 z06 came with. they are $6.40 each at autozone.
Old Jan 31, 2006 | 08:28 PM
Don't gap them, they come pre-gapped, just leave them as they are.
Old Jan 31, 2006 | 10:17 PM
is there a part number for these ac delco plugs?
Old Jan 31, 2006 | 10:49 PM
2MuchRiceMakesMeSick's Avatar
You always need to check them because they rarely are all gapped the same.
I use NGK TR-55s for NA along with 95% of the people on this board with no trouble.
Fact of the matter is the iridium coating often comes off after a few WOT runs.
Old Jan 31, 2006 | 10:52 PM
according to several other corvette forums, it seems to be a toss up between expensive AC Delco Iridium plugs and the inexpensive NGK TR55 plugs. AC Delcos work best at the preset gap of .040 and the NGKs work best at a .050 gap. MTI claims that NGK TR55 plugs are factory heat range and its backed up by other members of other forums. i can't see myself spending $64 for a set of plugs, therefore i've made up my mind and i'm going with the NGKs. Thanks for all your help and support guys.
Old Feb 1, 2006 | 11:01 AM
that is going to be a wasted 20 bucks on plugs for no reason. i know for a fact that 04s came with iridium plugs and my z06 didnt respond very well to the ngk's. may be it is just 04s that perform better with the ac delcos, but from my own experience i would buy the stock ones again. also, it isnt 64 dollars..it is $48 and change.
if you go the cheap route then it is going to cost you more later. i was told by lou from lg motorsports to put stock plugs back on the car and get rid of the ngk's.
Old Feb 2, 2006 | 04:55 AM
Patman's Avatar
I've always had great results running NGK TR55s at .050 in all my LS1 powered vehicles.
Old Feb 2, 2006 | 11:09 PM
Dragman's Avatar
Dont have any issues with NGKs here!
Old Feb 2, 2006 | 11:22 PM
TR-6's for me (nitrous application)
Old Feb 3, 2006 | 09:36 AM
FACE's Avatar
TR55's are the same heat range as stock, I just researched this the other day.
