Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
corvette rear end leak
Old Sep 27, 2006 | 02:20 PM
20ls100's Avatar
Default corvette rear end leak
hi all, how hard is it to replace the axel seals on a 2000 coupe? it looks straight forward, so what suprises will i encounter? thanks
Old Sep 27, 2006 | 04:43 PM
MJD's Avatar
MJD
You may want to check with a dealer about this. If I remember right there was a recall regarding this.
Old Sep 27, 2006 | 09:22 PM
Cajundude's Avatar
Output shaft seals are easy. Cover seals are more difficult. Which one is leaking?
Old Sep 28, 2006 | 06:34 AM
charlie c5's Avatar
Pulling the half shafts are not a real issue, just take your time, and you'll be fine. It helps to have a friend help you...
Old Sep 28, 2006 | 07:45 AM
Cajundude's Avatar
Look here for my how to on the output seals.
BTW, charlie C5, is that your car in the sig? That is badazzzzzzz! I see you are in Houston, can you come out to the event that I have coming up? Details are here .
Old Sep 28, 2006 | 07:49 AM
20ls100's Avatar
its the output shaft, i ordered the seals from the dealer yesterday,only one is leaking now but im going to do them both while im at it. do you think im thinking right to do them both?
thanks for the replys, mitch
Old Sep 28, 2006 | 08:56 AM
vetred's Avatar
yep,..........Next to the steering wheel lock, this is the most populer recall!
Old Sep 28, 2006 | 09:00 AM
20ls100's Avatar
would they cover a 2000 with 30,000 miles?
Old Sep 29, 2006 | 12:23 PM
20ls100's Avatar
bump. will this still be under warranty?
Old Oct 1, 2006 | 10:01 PM
thetight's Avatar
hey i just got my car this july and was changing the fluids and saw my rear diff leaking under the driver side i checked with the local dealer and they said there is no recall?? my car is an 02 coupe m6 has 54.5k on the clock was the dealer wrong abot the recall?
Old Oct 2, 2006 | 02:16 PM
JPBabyRange's Avatar
I just posted this the other day- mines leaking too- is there a recall??
Mines a 2000 FRC w/ 32000 miles
Old Oct 2, 2006 | 03:22 PM
Black8Banger's Avatar
mine is leaking too....anyone know for sure about the recall?
