Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
car is going friggin insane
Old Jan 28, 2007 | 03:50 PM
jbusmc1986's Avatar
Default car is going friggin insane
I have no clue what the hell is going on, it feels fuel starved, it just started when I pulled up to a light yesterday, it has been idling really rough, bearly above stalling any where from 350-500 rpm and sometimes even lower, it will fall on it's face when trying to drive and has no power whatsoever, the damn thing wants to die all of the time, I put fuel injector cleaner in it today to try and help out, but it has done just about nothing at all. Here are the codes that I have been having since this started.
ok I added fuel injector cleaner with no help... here are all of the current codes
PCM
P0101 H
P0131 H C
P0151 C
P0174 C
P0300 H
TCS
U1016 H
SVM
B1001 H
U1016 H
IPC
U1255 H
RFA
U1016 H
Any help would be greatly appreciated especially considering the fact that this is my dd... btw at some points it has a strong rich smell
Old Jan 28, 2007 | 04:38 PM
03 BUSA's Avatar
My first thought is bad PCM, especially with all those codes. That is not normal.
Old Jan 28, 2007 | 09:37 PM
TamGTO's Avatar
I am no professional, but I would check grounds and the battery also...
Old Jan 28, 2007 | 09:48 PM
7camaro7's Avatar
I had 9 codes on my SS last week and the guy at the shop told me nobody has 9codes at one time and it was most likely a fuse. It was a fuse under the hood. To me it sounds like your spark plug wires or coil packs may be bad. Check those too
Old Jan 29, 2007 | 10:26 AM
DocT's Avatar
All of them though??? is that likely that all of them are going bad?
If you all of the sudden got all those codes like that, I'd bet it's something simple...Hopefully! Good luck!
Old Jan 29, 2007 | 10:37 AM
273sunsetZ's Avatar
I had the same problem a week after I bought the car, it was still under the limited warranty so I took it back. I believe the problem was a vacume hose (not positive though) that got a cut in it; the suction in the hose caused the hose to collapse, and caused the same problems your having. I replaced the hose and it didn't fix the problem, so the dealer reprogramed the computer and it fixed it.
Old Jan 29, 2007 | 05:25 PM
jbusmc1986's Avatar
Do you know what hose it was?
Old Jan 29, 2007 | 06:47 PM
Jayzvette's Avatar
P0131 Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 1
P0151 Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 2 Sensor 1
P0174 Fuel Trim System Lean Bank 2
My guess is that the air bridge is sucking air after the MAF.
Make sure all connections and clamps are tight near and around the air filter
Old Jan 29, 2007 | 10:11 PM
jbusmc1986's Avatar
Thanks... I will give it a try tommorow
Old Jan 30, 2007 | 11:24 PM
2MuchRiceMakesMeSick's Avatar
sounds alot like a grounding problem to me.
have you checked the grounds yet?
Old Jan 30, 2007 | 11:29 PM
jbusmc1986's Avatar
which grounds?
