Corvette Z06 Cam ???
Both of the cams listed above will require full bolt ons/supporting mods including going steeper on the rear gears to 3.90 or 4.11 (big $$$ on a C5 diff swap)
You've got weeks of reading if you look in the Internal Engine section...
www.texas-speed.com
You might want to shop around though. Just my 2 cents.
x2...A 228/232 .580ish lift on a 112LSA is what I'm thinking about with mine. You can keep your stock gears, minimal cam surge, and much better on longevity compared to an MS3.
I doubt you'd be really pissed off with the specs above, bigger than that and get your wallet ready for upgrades (diff, clutch, valve spring changes, etc)
my 100% bone stock c5 auto 2.73 gearrs...
13.5 at 102-103 consistently
same track in same hawaiian weather after installing stock 2002 LS6 heads and stock LS6 cam...
13.2 at 105-107 consistently
Then changed the cam to a 224/224 at the same track and same year long hawaiian conditions ran a.....
12.9 at 107-110 consistently
So the 224/224 was worth 3 mph and 3 tenths over my stock 2002 Z06 cam..
Still ran/idled like a stock car to boot
I personally know of an 03 Z06 locally with a MS3 and 3.42's. No headwork, just headers and intake. It made 420rwhp perfect drivability. TUNE is IMPORTANT!!!
Car doesn't need headwork. He mentions full boltons which I assume should include headers. Thats ALL he needs.
It's really up to you.. If you want a raspier type cam, then go for it. If you want a ***** cam, then do a 224 cam. It's all up to you.
Car will make over 400rwhp without headwork with a larger cam.
Werd.
If tuned properly the MS3 is very liveable, and you do not NEED gears for it, i highly reccomend it
I agree with Eurospec2. One can use a 'big' cam in a car if it is tuned well. Since the cars has ZO6 heads, I would go on the larger side 229/229/580ish/580ish//112 to 232/232//580ish/580ish//112. If you do mind a little lope, drop the LSA down to 111 or 110 and drop the power band in RPMs.
Keith
You're head's in your azz if you think a 239+ duration cam is going to be the clear choice for all people.
There's a hell of a lot more involved to make it drivable than "GOOD TUNING" unless you're a mullet mechanic.
What would John Lingenfelter say when building "top-shelf" daily driver Corvettes for his customers? What are the typical cam specs he uses?
I'm sure Lingenfelter says, "It's really up to you.. If you want a raspier type cam, then go for it. If you want a ***** cam, then do a 224 cam."
Keith
I'd get sarcastic,(for fun) but I've got a person coming in to sell me his '88 Anniversary with 29k miles- he'll be here in less than 20 minutes and I need to set up the check/papers.....
and right after that set up the financing for the guy buying an '02 Lingenfelter supercharged/modded coupe at the end of today before he has to drive it back to South Carolina.
I'm no expert, but I'm not a ***** either, I'll gladly dispense my version of mullet tech
if you'll let me know what you need solved....In a couple hours I'll have some time.
RobG03Z06... What wheels are those? Nice..
