Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
01 Zo6
Old Nov 4, 2007 | 03:33 PM
pewter2165's Avatar
Default 01 Zo6
Hey Guys,
I just bought my first corvette, Its a O1 Z06. I would just like to know what are the most common problems seen with these cars? Are they pretty durable? If some one can provide me with some feed back on their experiences with these car it would be great. Thanks.
Old Nov 4, 2007 | 04:10 PM
noah98SS's Avatar
sometimes when I take off to fast the back tires start smoking........,congrats on the new ride
Old Nov 4, 2007 | 04:19 PM
pewter2165's Avatar
Old Nov 4, 2007 | 04:39 PM
~JOSHUA's Avatar
I drive mine hard.... really hard. They were designed to take track abuse... (shot peened ring + pinion, better clutch, etc)
Strong machine, daily driven with no problems in 50k miles...
Old Nov 4, 2007 | 04:55 PM
pewter2165's Avatar
I Heard the T56 are a little noisey on these things cause the gears are harden is this true?
Old Nov 4, 2007 | 07:19 PM
pdd's Avatar
pdd
hahah
Old Nov 4, 2007 | 09:39 PM
delsold's Avatar
do z06's have the t56, or is it the mn12 or whatever that tranny is called?
Old Nov 4, 2007 | 10:13 PM
flynlow3's Avatar
It is a mn12 for the z06 and t56 for the standard c5 manual and 4l60E for the auto coupes.
Old Nov 4, 2007 | 10:54 PM
pewter2165's Avatar
Thanks for the info.
Old Nov 5, 2007 | 12:21 PM
delsold's Avatar
the differences are just gear ratios correct?
Old Nov 5, 2007 | 12:41 PM
~JOSHUA's Avatar
Yes, all ratios are different except 4th -Reverse is shorter too.
Old Nov 5, 2007 | 06:49 PM
delsold's Avatar
what final drive ratio do they have...is it 3.42 like the t56 fbodies?
Old Nov 6, 2007 | 09:43 PM
pewter2165's Avatar
Anybody else have any input on these cars.
Old Nov 6, 2007 | 10:12 PM
z06 mike's Avatar
Thay come with 3.42 gears but the clutches in the rear are set diffrent for performance. You will notice on the tag that they say 3.42 sp and the standard vettes just say 3.42. Down fall in the 01 are the piston rings under heavy driving you will notice oil going low about every 1500 miles. Really nothing to worry about just make sure you check your oil regurly.
Old Nov 6, 2007 | 10:22 PM
delsold's Avatar
did thy change that in 02-04
Old Nov 6, 2007 | 10:37 PM
z06 mike's Avatar
If you are talking about the piston rings yes. The rearend I dont think so.
Old Nov 7, 2007 | 12:30 AM
SSilverSSurfer's Avatar
i was told that the 01' has oil consumption problems is this true? not really sure what that meant but it didnt sound good
Old Nov 7, 2007 | 06:52 AM
Mike00's Avatar
Some of them did yes. That's the piston ring issue talked about earlier in this thread.
It's good to take a look at the history and see if it has been re-ringed.
Old Nov 7, 2007 | 09:48 PM
vette ed's Avatar
have fun
Old Nov 8, 2007 | 02:30 AM
cantdrv65's Avatar
Post
My 01 has never burned oil.....
I really haven't had ANY problems to speak of since I got the car. I busted a timing chain once, but that was the previous owners fault for not changing it when he installed an aftermarket cam....that caused me to get new heads, but I'm still on the same shortblock.
