Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
what size cam?
Old Nov 14, 2007 | 05:23 PM
hotsauce886's Avatar
Default what size cam?
i have a 98 c5 M6> borla stinger exhaust no headers. thats how the car was when i bought it. i am gettin headers.. not sure which ones? but as far as a cam... what is good for my car. i will be gettings heads eventually...but i want to go ahead and cam it now
Old Nov 14, 2007 | 05:49 PM
2MuchRiceMakesMeSick's Avatar
Need more information cause there is too many variables. What do you want to do with the car? Daily driver?
I would go with LGs headers unless you need 1 7/8" in that case I would get Kooks but they are something else to install
Old Nov 14, 2007 | 06:00 PM
Chevy406's Avatar
My '99 is a daily driver, so I decided on a mid 220's duration cam. I haven't completed the install yet, but it is getting a 226° duration with .585" lift Patriot Performance cam.
Old Nov 14, 2007 | 07:07 PM
it will be a daily driver for the next few months then it will go to just weekends. lg headers are like 1500$
Old Nov 14, 2007 | 07:13 PM
02white6.0's Avatar
TSP makes a nice set of longtubes for around $500. Ill be picking up a set soon from them and I just bought a 224/228 .581/.588 110lsa cam for my car, I had a Magic Stick3 in my Z28 and it was a tad much on the street for me taste, but made GOOD power!
Old Nov 14, 2007 | 09:05 PM
smellya's Avatar
I just did 230r cam on a 113lsa with afr heads and fast 90/90. I have kooks 1 3/4 longtubes. with stock ti exhaust. It did 464/429 to the wheels. Its plain crazy to drive
Old Nov 14, 2007 | 10:16 PM
1bigcamdls6's Avatar
go with a cam in the 230's for good mid-range power my cam profile is in my sig and it makes garbage for low end but screams high end
Old Nov 15, 2007 | 07:12 AM
scramblerman's Avatar
What he said. Those Kook's 1 7/8" race headers are something else to install.
Cam really depends on what you want and how much pwoer you want to make.
Old Nov 15, 2007 | 07:31 AM
2006vette's Avatar
Welcome to the world of the "vette tax". It only gets worse. Wait until you see the price of a good CAI.lol
Old Nov 15, 2007 | 04:51 PM
Default cam
i guess ill go with one around the upper 230's
Old Nov 15, 2007 | 05:41 PM
probably a 239! or maybe the tsp MS3 or MS4 not to sure. what should my lobe separation be? standard 112 or what?
Old Nov 15, 2007 | 06:39 PM
ctusser's Avatar
I'd go with the widest separation they offer for a cam that size.
Old Nov 22, 2007 | 12:42 PM
luch90's Avatar
id recommend something lower in the 230s or possibly high 220s for duration if you want to
be able to use 6th gear and have some driveability still
Old Nov 22, 2007 | 04:10 PM
~JOSHUA's Avatar
If you go into the 230's (even with good tuning) you'll have it surging in 6th gear on the interstate (herky jerky crap) It will force you to put the shifter in 5th down the interstate and you'll see the mistake you've made.
I suggest 228 intake.. and give the exhaust a little more time 232 keep the lift under .590 and run Comp 918 springs, add an underdrive pulley, the $500 TSP headers and a nice tune... you should be happy with that combo..
The LSA will make it sound however you'd like..
114 light burble at idle, some will know it has a cam, some wont
112 light/good chop at idle, only idiots will think it's factory
110 most guys wont race if you pull up at a stop light... SKEEERD!!!
Old Nov 22, 2007 | 04:21 PM
BitViper's Avatar
I see LA as your location..if thats Los Angeles..youve also got to iworrie about getting it to pass smog..If I remember right getting anything smaller than a 112 to pass smog is a real challenge
Old Nov 23, 2007 | 05:31 PM
my 6th gear does not surge still has ok pickup but not as good low end as b4 the cam
Old Nov 23, 2007 | 06:42 PM
pittman's Avatar
Here is a clip of my 224/224 /590 - 109 LSA, 6th gear is great even at 55 mph. Will give you an idea of lope. Pit-man
http://s160.photobucket.com/albums/t...ZO6Exhaust.flv
Old Nov 23, 2007 | 09:27 PM
~JOSHUA's Avatar
Nice!
Old Nov 24, 2007 | 02:37 AM
Cole Train's Avatar
i've got some 243 cast Z06 heads going on my C5, Magic Stick 4 cam(MS4) TSP longtubes with their X-pipe, LS6 intake and T/B, Underdrive, and a dyno tune and i'm gonna be hoping for around 475+ RWHP I'd say get the TSP headers. they are cheap and great quality, and if you wanna have a big cam the MS3-4 are good choices but you'll have to get PRC double springs and Chromoly Pushrods to handle the lift I personally can't WAIT to get this baby together~Cole~
Old Nov 24, 2007 | 09:34 PM
Bullitt4110's Avatar
I have a 238/244 .605/.612 114 and drive close to stock while cruising with no surging or anything like that. Thats all in the tune! If your getting surging and your tuner cant fix it, its time to find a new tuner! Its not my daily driver, but it could be if I needed it to be w/o any probelms.
