Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Spraying a automatic vette what do I need to watch out for
Old Dec 24, 2007 | 03:33 PM
Slow TA's Avatar
Default Spraying a automatic vette what do I need to watch out for
I'm gonna spray my 02 automatic vette just a 100 shot I was wondering since its an auto what should I look out for and would I need anything like a tranny cooler etc.
Old Dec 25, 2007 | 03:18 PM
Shoaf85's Avatar
Probably the biggest thing will be having a window switch so you don't have the nitrous spray into the rev limiter and a tune would be really nice as well, it would help the shifting with the added power!
Old Dec 26, 2007 | 09:13 AM
ls1290's Avatar
Dumb Ass Vette Moderator
A window and WOT( wide open throttle ) switches are defiantely a must on an A4. Also have the A/F ratio checked after the kit is installed. Even with the correct sized fuel and N2O jets installed, the A/F ratio can be a liitle off. I would also get a Timing Tuner module. That way you can pull a couple degrees of timing out when you run the nitrous and add the timing back when you are not.
Keith
Old Dec 26, 2007 | 10:36 AM
z28hustle's Avatar
so do you guys think he needs to watch out for any damage to his tranny? im not sure on the amount of power hes going to be putting out but i would think he is getting close to that auto tranny breaking point...
Old Dec 26, 2007 | 10:43 AM
ls1290's Avatar
Anything more than stock HP applied to the 4L60E is going to cause stress and damage to it. The stock 4L60E is really a POS IMO. If he has stock gears( 2.73s or 3.15s ) with a stock stall, he should be fine running a 100hp every now and then. If he does have aftermarket gears and/or stall, a tranny cooler is a must! Some people will suggest a tranny brace, but it is a bit overkill for a 100hp wet shot.
Keith
Old Dec 26, 2007 | 10:45 AM
Slow TA's Avatar
so deff a tranny cooler just to be on the safe side
Old Dec 26, 2007 | 10:47 AM
z28hustle's Avatar
thats kinda what i was thinking but didnt want to say the wrong thing ... thanks for the info!
Old Dec 26, 2007 | 05:42 PM
BlownVette 2001's Avatar
A fire extinguisher.
http://forums.corvetteforum.com/show....php?t=1896615
Old Jan 4, 2008 | 12:07 PM
vette#3's Avatar
I can tell u ,that from myself spraying a 100 shot on an a4 ,i went thru 2 trannys ,the 3rd one is an Flt tranny & It has been bullet proofed ,i would have a window switch & The appropriate pills on the switch ,so u can control when it comes on ^& when it shuts off ,i just sold a msd switch that was allready modified to run with the Ls1 or U have to send it to Msd & They have to modify it ,or u buy one from tbyrne ,like i did thats allready been modded ,there a 100.00 & they may save your motor ,well worth it imo ,o ya another thing ,try not to Wheel hop or u will be putting in an hardend outputshaft,most of the time they break on the drivers side ,there the weaklink in the c5 rearends
Old Jan 7, 2008 | 12:10 PM
will82's Avatar
From: Somewhere Between Mild Insanity and Complete Psychosis
start saving for a transmission.
stock stall, stock 2.73 gears, stock shift rpm, stock cam, run flat tires, blower on low boost toasted my tranny after 2 months. some get lucky, don't assume you will be, start saving pennies now.
