Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Pit-man \ Rev-Extreme Stroker update
Old Feb 13, 2008 | 06:58 PM
pittman's Avatar
Default Pit-man \ Rev-Extreme Stroker update
Well, if dropping a valve at 6500 rpm on New Years Eve wasn't bad enough, my AFR head got hammered, piston broke and cylinder scarred. So off to the machine shop for a sleeve in # 6 and then Tracy at Rev-Extreme was going to start on my stroker. Everything looked good till the machine shop cracked my block putting in the sleeve. Tracy was able to find a used LS6 block for $250. Here is where we are today. AFR heads went in for repair..parts arriving daily.
New Block http://i160.photobucket.com/albums/t...strokerkit.jpg
New Cam bearings
http://i160.photobucket.com/albums/t...bearingsin.jpg
My Fast is ported and new TB in place
http://i160.photobucket.com/albums/t...ortednewTB.jpg
Pit-man
Old Feb 13, 2008 | 07:49 PM
Zturd's Avatar
Looking good pittman..... I'm curious as to why the new fuel rails???? Plus i'm really curious why the TB appears to be upside down??? The actuator looks like its on the opposite side? Is there something you're not telling us?
Old Feb 13, 2008 | 08:51 PM
pittman's Avatar
Default Large Fuel Rails
Z, if you notice, the fuel rails are about 75% larger than the original. Tracy is running some stealth nitrous lines inside the fake larger rails. He saw your post about adding a 100 shot to kick my a*s and came up with a plan...haha.
I don't know whats up with the new rails actually or about the TB. I know when I put on the Fast and LS2TB last year, I had to mount it upside down because it wouldn't fit because of the power steering. I think the new vetts might be that way also ?? See the pic of my old setup below.
http://i160.photobucket.com/albums/t...e/DSC01073.jpg
By the way, what brand tire are you using for skinny's ? Are they 16" ?
Pit.
Old Feb 13, 2008 | 09:22 PM
Zturd's Avatar
Running some nice azz Sumitoma or some cheap azz radial up front like you're not supposed to 15in
Old Feb 14, 2008 | 06:12 AM
Shoaf85's Avatar
Nice man can't wait to see your results when it's all finished up!
Old Feb 14, 2008 | 08:46 AM
pittman's Avatar
Default AFR Heads
I will try to post some pic's as I go.
Just got word my AFR heads survived..so back with my 225's.
Pit
Old Feb 14, 2008 | 03:07 PM
pittman's Avatar
Default AFR Heads
This is what an AFR head looks like when you drop a valve at 6500 rpm...will make you sick !!
http://i160.photobucket.com/albums/t...lveAssault.jpg
Pit
Old Feb 14, 2008 | 03:09 PM
Sigforty's Avatar
Pit
That is almost any head when that happens.
Old Feb 14, 2008 | 06:36 PM
pittman's Avatar
No doub Sig..probably 200-300 hits before I shut her down. That would beat up anything. Thank goodness they can be repaired.
Pit
Old Feb 27, 2008 | 07:30 PM
pittman's Avatar
Default update
Update from Tracy @ Rev-Xtreme...waiting on heads...due any day now. I decided to go with fixing my AFR 225's instead of new heads. Pete Incaudo dropped by Tracy's and inspected the heads. He said to fix them, they wern't that bad at all. He gets them all the time in worse condition than mine.
Pic of engine bay http://i160.photobucket.com/albums/t...itingon383.jpg
Pic of paint protection http://i160.photobucket.com/albums/t...protection.jpg
Won't be long now...more pic's coming soon.
Pit
Old Feb 27, 2008 | 07:43 PM
TLewis4095's Avatar
Pit
Heads may be back this Friday!
Old Feb 27, 2008 | 07:57 PM
pittman's Avatar
That would be great Tracy. I am soooo ready to get back in my z !!!
Bowling Green is waiting on me.
Pit
Old Mar 18, 2008 | 07:18 PM
pittman's Avatar
Default 383 update
Tracy finally got moved into his new location, my heads are FINALLY back and below are the pics of parts waiting on Chris to do his majic ! Z promised back in 2 weeks...will keep you posted. More pic's and dyno sheet on the way soon. Lets rock and roll Chris !!!
http://i160.photobucket.com/albums/t...ishedcrank.jpg
http://i160.photobucket.com/albums/t...lancesheet.jpg
http://i160.photobucket.com/albums/t...de/Pistons.jpg
Pit
Old Mar 19, 2008 | 05:58 AM
Shoaf85's Avatar
Nice, I'm sure you're getting excited about it!
Old Apr 4, 2008 | 01:30 PM
pittman's Avatar
Default new update
Houston, we have lift-off !! Crank in block, pistons waiting in line, pushing and shoving to be next.
http://i160.photobucket.com/albums/t...bPbuild003.jpg
clearence necessary for stroker
http://i160.photobucket.com/albums/t...bPbuild004.jpg
Pit
Old Apr 9, 2008 | 01:10 PM
pittman's Avatar
A little closer
http://i160.photobucket.com/albums/t...de/TopView.jpg
http://i160.photobucket.com/albums/t...tonsrodsin.jpg
http://i160.photobucket.com/albums/t...epairedAFR.jpg
Old Apr 9, 2008 | 01:21 PM
AlexLs1's Avatar
Good luck with your build up! Must be exciting!
Old Apr 9, 2008 | 07:02 PM
pittman's Avatar
Yeah it is. Thx man
Pit
Old Apr 11, 2008 | 09:35 PM
pittman's Avatar
Default Almost Ready
PTV check
http://i160.photobucket.com/albums/t...e/PTVcheck.jpg
rockers on
http://i160.photobucket.com/albums/t...mostthere2.jpg
AFR'S
http://i160.photobucket.com/albums/t...lmostthere.jpg
pit
Old Apr 13, 2008 | 03:46 PM
V-seriesTech's Avatar
Pit
**** man.
