Car wont hook
Working on getting the vid up for this run.
last time it ran ---Went up to Great lakes dragway last night and ran a 11.91 @ 118 with a 1.71 60 foot car ran really good but bogged badly after dumping the clutch every time. i was dumping the clutch at about 5000 to 5200 think i need to go more but i am still happy for the first time out
This was my 11.91 Run
I am looking into QA1 drag set up sick of the hit or miss i want hook and book.
What psi in the tires when you launch?
burnout procedure?
torque arm?
pinion angle set to?
How are you sure what you are launching at RPM wise? eyeballing it?
What type tire (ET Drag, ET Street, M&H, drag radial, etc)
Just a few things I need to know to give you my advice....
around 15psi to 17
roll into water put the tire's right at the edge of the water 2nd gear 4000rpm and roll out of water at 6000
i have umi chas tq arm with loop
right know its at -3 angle
the vid was at about 5200 and the 2nd time out was at 5800 and 6000 it dont like anything past 5600 just spin's using a eyeballing
MT 26x10 15 ET street radial
around 15psi to 17
shocks definitely need to be replaced..... double adjustables preferably.... hooking on a radial is all about tire control and those stock shocks ain't gonna cut it.... Pressure is good.... burnout procedure good.... I"d say that's too much negative pinion angle... I'd go -1 to -2 max.... Try leaving at the same RPM everytime. Get a 2 step with a button (since you don't have a transbrake)..... YOu want to leave at WOT everytime on a limiter so you always leave at the same RPM..... more rpm = more likely to spin cuz you're hitting the tire harder... so when trying to sort out your suspension you can't compare cuz one pass you might launch at 5000 and another at 5500 or so... apples and oranges.....
so you need a 2 step and some shocks..... and another ta adjustment....
got it. Thanx
