Track Results - H/C M6 SS.... Have Questions
Old 05-05-2009, 10:06 PM
  #41
ATLSS's Avatar
LS1Tech 10 Year
Originally Posted by melchoir
MGW shifter doesn't have stops either, I like my hurst billet a lot.
I went with the Hurst Billet for the stops... cause you're right, the MGW does NOT have stops....
I've had my *** flamed over in the manual section for pointing this out about the MGW... oh well...
Old 05-06-2009, 11:26 AM
  #42
2002_z28_m6's Avatar
I brought up the same thing. They said that they were built into the shifter? Can that be? I was concerned about it.
Old 05-06-2009, 02:14 PM
  #43
ATLSS's Avatar
LS1Tech 10 Year
If "they" is MGW, then they meant that the stops were built into the T56...
If you'll search for my thread in the manual section you'll see the concern I had and why I went with the Hurst Billet.
Bottom line is - you need a shifter with stops.
Old 05-12-2009, 04:56 PM
  #44
ATLSS's Avatar
LS1Tech 10 Year
I've searched but could not find the answer to this question:
Anyone know what gain I will see in ET going from a 3.70 to a 4.30?
I'm running a 26" tall cheater slick that grows ~3/4"... and I'm calculating that the 4.30 will put me at peak hp or slightly over it at the traps...
Thanks guys
Anyone?
Old 05-28-2009, 01:44 AM
  #45
kmracer's Avatar
depends on your rev limit, but theres a good chart/calculator around here somewhere. you might want to look into a 28" tire with those 4.30's.
Old 05-28-2009, 09:17 AM
  #46
ndfrsd6's Avatar
i ran 4.56 with a 28in tire when i had my 6spd....so with your 4.30's go with a 28in et drag stiff wall .....the stiff wall tire will not distort as much and the sidewall will last longer
Old 05-30-2009, 08:19 AM
  #47
ATLSS's Avatar
LS1Tech 10 Year
26.75" (26" + .75" growth) tire + 4.30 gears = 122 mph @ 6,600 rpm
The limiter is set at 7,000 and I will be shifting at 6,800.
So, I don't need a 28" tire.
Back to the original question - does anyone have experience with swapping from a 3.70 to a 4.30 with ET/MPH results?
Thanks
Old 05-30-2009, 08:21 AM
  #48
ATLSS's Avatar
LS1Tech 10 Year
A higher power recommended the M&H for a stick car so that the sidewall WOULD take up most of the shock from cluch engagement...
Thanks though
Old 06-01-2009, 11:14 AM
  #49
CARTEK Racing
WS6TransAm01's Avatar
Originally Posted by Demonicbird00
the sway bar will help a lil.
short belt will help a lil, not 1-2 and not 1-2 mph.
you have good mph just not getting out of the hole quick enough, a 4.30 will help but itll be horrible on the street.
congrats
brandon
Thanks man.
The car is a M6.
The 4.30 shouldn't be too bad since I have (2) overdrives.
4.30's will be fine on the street with an M6... I have 4.56's and would go to a 5.00 if I could fit a 30" tire under the car.
The short belt helps, but not as much as 1 or 2 tenths... maybe .08?
Also, disconecting the way bar will help, but if you have it disconected from the A-arms... why not just let out the other 4 bolts and take if off all together? Less weight on the front...
The width of the tire is not as beneficial as the sidewall of the tire IMHO. I wuold go to a 15x10 rim in order to get the proper width rim for a 11.5" wide tire, and to get some more sidewall under the car as well.
The LPE launch control or any 2-step would help... I hope... LOL I got one, but never tried it out aside for on the street next to my house, and even at 3000rpm the car did not hook on DR, but thats public roads for ya lol.
Old 08-29-2010, 07:15 PM
  #50
ATLSS's Avatar
LS1Tech 10 Year
Updated ET/MPH with the 4.30 gear in Post #1.
Old 08-30-2010, 03:22 PM
  #51
1Bad97WS-6's Avatar
Congrats on the time.. Iam going with 15" wheels for my next wheels. Here is a list of 15" wheels will fit over the LS1 calipers..Billet specities,Bogarts,Convo Pro's,Race Stars.. Here is a website for the race stars. www.jimsracingtires.com Comes with Free shipping,Lug nuts closed,open,chrome value stems..
Quick Reply: Track Results - H/C M6 SS.... Have Questions
