Et Streets vs Et Drags
Old 02-23-2010, 11:59 AM
Zmg00camaross's Avatar
Nice run cant wait for spring.
Old 02-24-2010, 02:59 PM
4cefedz28's Avatar
nice, did you gain anythin e.t wise from the quicker 60'
Old 02-28-2010, 07:05 AM
2001z's Avatar
Drop the pressure a little bit and grab you a 2 step and let it eat.
Old 02-28-2010, 05:18 PM
Carter01's Avatar
I'm with ya brother. I think I'm going to try the rev limiter approach and see what it get's me. 6800 shouldn't be too bad on the drivetrain
Old 02-28-2010, 05:52 PM
223HAWK's Avatar
Youll find the weak link if ya got one..Thats my plan off the limiter!!
Old 02-28-2010, 05:58 PM
PowerShift408's Avatar
We've got pretty much identical cars and I went a 1.62 on ET streets (26x10.50x16) with 5-5.5k clutch dumps. Lots of tire spin though.
Old 02-28-2010, 06:16 PM
Carter01's Avatar
Yeah, I keep up with your car a little since I read you have the TQR2 cam like mine. I always like to see where I'm at with those with similar mods.
Yeah, with the ET streets I hit one 1.69 spinning sideways out the hole lifting the left front about 4 inches. I couldn't believe i still ran an 11.7. I plan on going back one last time while it is still cool down here to get some better NA times. I plan on spraying this winter so I want to know what my best NA can be before hitting it with the dope. Keep me posted on your times.
Old 02-28-2010, 06:18 PM
Carter01's Avatar
Well the only weak link I can think of is the input shaft. I have a built rear, suspension, driveshaft etc.. We'll maybe the clutch but it is a wear part so i know if i keep driving it like I do it will need to be replaced soon anyway.
Let me know how you do with your combo.
Old 02-28-2010, 07:02 PM
What do you spin your motor to? I'm probably cutting myself short as I shift at 6200-6400 (Stock rod bolts). My car has never even thought of lifting a tire. Impressive trap speed for that as well, mine's never com close to that. That may be part attributed to my lower shift points. Who knows. Mine made 400/370.
That setup won't ever see that track again as my setup is making a big change soon. I'd elaborate but there's been some locals looking at my posts.
Old 02-28-2010, 07:50 PM
Carter01's Avatar
I understand about the locals, lol.
I shift at 65-6600, with my stock rodbolts. I made 392/362 with the 10bolt, high flow cats. I now have a 9', no cats and a spool so probably about the same as before, maybe a little more like you. Forgot, just got a 3' cutout also.
As for lifting the tires, been doing that pretty consistent each pass since the Strange DA shocks. Last outing it pulled both, looked and felt pretty cool!
Old 04-03-2010, 05:26 PM
Ace5Oh's Avatar
Nice.
Quick Reply: Et Streets vs Et Drags
