Et Streets vs Et Drags
Old 02-17-2010, 11:40 AM
Carter01's Avatar
Default Et Streets vs Et Drags
Thought I would post up this video since I see alot of questions about what tire works for what car. I ran MT Et Streets 26x10.5x16 and my last track outing I cut a 1.75 60ft with a best of a 1.69 on those tires. I just switched to MT Et Drags 26x10x15 and dropped to a 1.63 and I believe I would have gone 1.5s if I could have gotten more passes but due to a race going on the T&T scene was low on the totem pole for getting track time.
First pass was 1.70
Second pass was 1.67
Third pass was 1.63
The harder I left the better the 60ft, with the Et Streets I could not do this, I would spin at least 3 revolutions on the hit each pass.
+1 for the Et Drags!
http://www.youtube.com/watch?v=bPxmvWD1Tvc
Strange Da, LCAs, TA, SFC, PHB
Still working on the launch, not quite ready ot leave off the rev limiter but heading in that direction.
Old 02-17-2010, 01:31 PM
MikeG's Avatar
Time for some 6000 clutch dumps!
There's a reason they're called ET Drags...
Old 02-17-2010, 02:05 PM
boostednismo's Avatar
Nice run. Do you go to SGMP often?
Old 02-17-2010, 02:21 PM
Carter01's Avatar
Yeah your right, just haven't really had the money lately to not worry about tearing stuff up. Things are looking a little better now so the next track outing I'm going to let it rip. By the way I always drive to and from the track so if I break I have to phone a friend for a trailer. Part of the game, I know
Old 02-17-2010, 02:24 PM
Carter01's Avatar
Not too often, about 3 or 4 times a year. Where are you located?
Old 02-17-2010, 02:29 PM
Statesboro. Some friends from Douglas and I go there a good bit.
Old 02-21-2010, 12:49 AM
02CamaroSSLE's Avatar
looks like that explorer gave you a run for you money , nice pass!
Old 02-21-2010, 09:39 AM
Ph.D. in HUBRIS
custm2500's Avatar
What kind of power are you making? Good to see that the drags helped you out. I would imagine a few more runs will help you out. If they were brand new they take a few runs to get broken in. So you will drop a good bit more if you are still spining at all. If they are already broken in then you will just need to up the launch rpm and continue to kick some ***.
Old 02-21-2010, 10:07 AM
01SS99red's Avatar
What gear are you running? and what power you putting down?
Old 02-21-2010, 10:12 AM
223HAWK's Avatar
Like to know a bit more info about the car like above guys have said..
Old 02-21-2010, 06:33 PM
Carter01's Avatar
392/362 to the tires
410 gears
Drags were brand new, only three passes
Torquer2 Cam, LTs, LS6 Intake, Lid, FTRA, PHB, LCAs, Tunnel Mount TA, Strange DA Shocks, SFCs, Moser 9, PST 1000hp DS. I think that's all?
Old 02-21-2010, 06:35 PM
Carter01's Avatar
Funny you say that, for those that know me my wife has an Explorer the same color and was talking trash about us racing. LOL
Old 02-21-2010, 06:39 PM
223HAWK's Avatar
Iv get a taller tire, and a 2 step and see how that does..She still looks like it spins a bit, pressue could play a big part in that also..
Old 02-21-2010, 08:06 PM
N2RACINGLS1's's Avatar
From the looks of the video I would think that you need 28" ET Drags. Look at the left wheel when you dump the clutch? I bet in slow motion the rim is close to hitting the ground! The 28 inch tire would take some of the shock out from the rear hit.
On a stick shift F-body car M/T usually suggest using the stiff sidewall, is that what you went with? Also are the tires screwed to the rims? If not you more than likely are having some tire slip.
Good luck and be safe!
N2
Old 02-21-2010, 09:51 PM
krazy4's Avatar
Pulled the tire
Old 02-22-2010, 08:26 PM
1Bad97WS-6's Avatar
Nice running car.
Old 02-23-2010, 07:46 AM
TravisA's Avatar
How did the two timeslips compare to one another? Et street vs drag?
Old 02-23-2010, 10:37 AM
Carter01's Avatar
Originally Posted by 1Bad97WS-6
Nice running car.
Thanks, been a work in progress. Going to spray it this year if all goes well.
Old 02-23-2010, 10:43 AM
Carter01's Avatar
1/8 et was a little quicker like 7.52 vs 7.55 and 1/4 mile was exactly the same. The reason behind this was a 25-30 mph headwind that was slowing everybody down. I ran an 11.75 before on the ET Streets with a 1.75 60ft. My car consistently picks up 1.5 in the 1/4 for every 1 tenth I make up in the 60ft so if all things were equal I feel that pass should have been a high 11.50, but without the slip "it is what it is", maybe next time.
Old 02-23-2010, 11:30 AM
7 Second Club
Villain281H's Avatar
Location: Gainesville, Florida # of drag strips runs: ?!?!?
ET Street slicks are going to have a few more cords in them versus a ET Drag slick, thus possibly part of your spin problem. I used to run 28 x 12.5 ET Streets but they would spin off the transbrake (M/T said the rebound from the sidewall was likely causing it, and if I wasn't limited to the tire by class, try an ET Drag instead). I went to ET Drag 28 x 10.5 stiff sidewall and no problems now.
Derek
Quick Reply: Et Streets vs Et Drags
