First Runs in the car
Old Apr 29, 2010 | 10:16 PM
05GTO6SPEED's Avatar
Default First Runs in the car
well i ran the car for the first time tonight and i need tires bad because its spining now with just a lid and cat back. i wanted to get some base runs before the converter and hd-2 install so it ran 8.83 @ 82.4 and 60's were 2.1 in the 1/8
Old Apr 30, 2010 | 04:42 PM
blk/slvr02ss's Avatar
The Yank SS3600 impressed the **** out of me.I used to tell a bunch of guys i hung around w/ i could run 12's w/ a bolt-on car and a converter and now i tell them how wrong i was and should have told them 11's.It will be the best move u make w/ your car.
Old May 1, 2010 | 09:56 PM
2002-Z28's Avatar
05GTO6SPEED my best run is about the same as yours 1/8 2.17 1/8 8.89 mph 82.8 1/4 13.66 mph 103. How is regular traffic driving with a 3600 stall does motor have to spin that rpm to get moving ?
Old May 1, 2010 | 10:11 PM
1BAD_LS1 Tunes's Avatar
if you get a good stall it will drive almost like stock! Then when you punch it its a whole new animal!!!! there are alot of sponsors on here who sell damn good stalls! Get a 3600+++ stall, if you go smaller you will regret it!
Old May 2, 2010 | 05:44 AM
If u spend the money on a good one the dont even notice the difference until u punch it.Yank,FTI,Vigilante are a good choice.
Old May 2, 2010 | 09:37 PM
smokiechicago1988's Avatar
My yank 3200 was the best mod I did when I got my FLT level 3 trans.
Old May 4, 2010 | 09:23 PM
the converter is not installed yet, but when it was in my truck it was like stock till you got on the gas and then you better hold on lol. my 04 Z71 with the yank 3600, LT's and a small cam it would bark the front tires every now and then on a good takeoff.
im wondering how the converter is going to do with the 2.73 gears, i guess it would be fine but ive been told the gears affect the converter somhow
Old May 4, 2010 | 10:24 PM
custm2500's Avatar
Ph.D. in HUBRIS
Originally Posted by 05GTO6SPEED
I'm wondering how the converter is going to do with the 2.73 gears, i guess it would be fine but Ive been told the gears affect the converter somehow
A converter stalls with a combination of power put in, and resistance against what it is putting out. More power the higher a converter will stall to, the heavier or "seemingly" heavier the car is the higher it will stall. Therefore gears make the car feel lighter or heavier and change the stall rpm slightly.
Old May 6, 2010 | 09:41 PM
well i put the converter and HD-2 in today and it is a lot better but now i need Sticky tires and some gears these 2.73 suck lol
