Finally got a little traction!
Ever since I installed my SS4000 I haven't had any luck hooking with my Nittos. So I ponyed up the coin for some ET Streets and FINALLY got some traction! I ran a 7.8 with a 1.7 60'.
It could've been a lot better, I still had to feather it out of the hole. I was in a rush to get to the track and forgot my tire pressure guage
. I thought I was running 30psi, which is what I asked the shop to put in them when I got them mounted. I checked them when I got home, turns out they were pumped up to 42psi
If I lower the pressure down to the low 20s I think I could knock off a low 1.6 or even a high 1.5.
Here's the vid of my best pass
http://youtu.be/UjATpJY16Yo?hd=1
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
Hey good job. At first I was having traction issues after my stall also. Would you believe it was because my motor and trans mounts were toast?
MT drs are great thats what im running now but if you really wanna get a good tire for the track get some hoosiers. I will be picking up another pair for track only.
Anyway great vid and good job!
I usually just give it a little to take the slack out. Probably 1000 rpm then put the hammer down wot.
My thread is here with all the info.https://ls1tech.com/forums/11-second...id-inside.html
Im adding 100lbs back to the car soon. But ill be doing heads and cam to so ill trade 100lbs in exchange for 100rwh
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
I'd say it would be worth it, your nose might come up a good bit more though. That was a great run, looks like on your 11.918 run you were 7.5 in the 1/8. I'd love to be able to get down that low. I looked up the DA and was at 1325' when I made my pass, hopefully we'll get some better and and I and I'll dip down close to that.
Nice pass. What track was you running at. I'm gonna go to motor mile when I come down this summer to visit family. Hopefully by then I will have everything done in my Sig..
![Punch](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_punch.gif)
