Terrible H/C times
Terrible H/C times
Here is an update to my previous thread.
https://ls1tech.com/forums/drag-racing-results/562394-whats-wrong-here.html
Went to the track this past weekend with a new fuel pump and set of M/T DRs hoping to at least hit low 12s. This was my best time, off my memory, don't have the timeslip with me currently but will update with full slip tonite. My runs were all pretty consistant within a tenth or two.
60' 1.79
1/4 ET 12.59
1/4 mph 111
I hit a lot of 108mph runs as well. Any ideas? I'm thinking my injectors may be maxed out.
60' 1.79
1/4 ET 12.59
1/4 mph 111
The injectors are not maxed out or at least that is not what is slowing you down. Have you been to the dyno after the re tune? Without any more info here I have to be thinking converter. I don't see anything else that would hinder your car? Or not with 380 plus hp to the tires. I ran 7.40s with 1.7 60's and dynoed 370 tuned on a Mustang dyno. Unless your weight is like 4400lb. My car probaly weighs 3550-3600 with me in it.
https://ls1tech.com/forums/showthread.php?t=562394
60' 1.79
1/4 ET 12.59
1/4 mph 111
60' 1.79
1/4 ET 12.59
1/4 mph 111
7 Second Club
Your track altitude
Air temp
Barometric pressure
Dew point
www.weather.com and input zip to get close, track should have a web page that lists altitude
Air temp
Barometric pressure
Dew point
Said it before and I'll say it again, you need to change that converter for something with more stall. I suggest a Yank only cause a buddy of mine has cheaped out on at least 10 converters until he finally got a Yank. Well guess what, the Yank gave him his best ET and MPH ever. Your torque is really low, I had the same problem when I had a ProTorque 3500 stall in my old H/C (TEA 1.5s/TR 224/Pacesetters) 98 Z28. It still ran 11.8s at 115 w/a 1.64 60' at full weight on 245 Nitto DRs (stock 98 injectors, no tune, 15* of timing due to a bad knock sensor, bouncing off the rev limiter on 2-3 shift, 75-80* day). When I replaced the TR224 cam for an R1 (still no tuning) I dynoed the car and made 372/320 unlocked. Junk converter (but it did pull the left wheel off the ground lol). Never ran the car at the track with the R1.
Now, I don't necessarily think that's the only problem you have. Log some runs and see what the hell is going on. I doubt it's the injectors unless they're real dirty/clogged.
Who did the tuning on the car? Have you done a compression/leak down test on the car?
I couldn't find the altitude on there website, which hasn't been updated in years, but if you wanna look up the location the zip is 48446. As for the converter, I know. I have a Yank SS4000E sitting in my garage but it has to be sent to yank to be looked over and this winter I was planning on swapping it in. The car is tuned by a local guy who tunes many cars and is highly recommended, he also tuned the car when it had my old LPE cam in it and that ran a faster 12.55 at 114 on Nittos. Right now everything and anything is possible, its just a matter of narrowing it all down. The trans doesn't feel like its slipping but I know it won't last forever and maybe it is on its way out.
Originally Posted by n2o
Yeah mph in the 1/4
And 8.2 in the 1/8 is a horrible ET for almost 94 MPH of trap speed. My car did 7.81 @ 88.5 - 89 MPH. I would expect your car to be running mid 7's in the 1/8 no problem with that kind of MPH.
It sounds like you need to data log that thing on a 1/4 mile blast to see what's going on.
What gear are you running in it? With that sized cam, I'd think you would need a 3.73 - 4.10 to really make it work.
Just tossing in my $0.10 worth...
Well other than the very shitty trap speeds the trans seems to shift perfect but I would suspect the converter although it has never seemed to run oddly. I'm currently on the stock 3.23s since there is no use to swap until I get a 12 bolt, but I know that a higher stall will do wonders. Could a converter that is slipping cause most of the loss in mph here?
Moderator
Assuming your passes were at 3pm on the 23rd the DA was 2390ft
Elevation at Zip code 48446 is 846ft
Temp was 72
Dew point was 63
Barometric pressure was 29.70
Corrected to sea level mph and ET 12.25 @ 114 1/8 = 7.99 @ 96.53
My head and cam car usually gains ~24mph from the 1/8 to the ¼ which based on your uncorrected 1/8 mph your ¼ mph should be ~ 118mph
John
Temp was 72
Dew point was 63
John
