New Cam only bests with my G5X4
This all happened at a track rental today here in MD. Race weight is 3600 lbs. All in all I am happy the car has come this far and hopefully with a little weight reduction it should run 10.9*'s. There were some passes where I went 7.15 in the 1/8th at 96 mph and these definitely would've been 11.1* passes but because my stick was loose I missed 4th and went into 6th.
larry, congrats man! you have worked hard as **** at that car for forever and now it starts to pay off. even though your hardheaded im glad for your new best especially since its cam only at your weight
Originally Posted by gator's 99TA
you did that at 3600 lbs? thats nuts. your 60' isnt that great for that sort of et (when you think of the weight of the car). it must move out in the midrange.
Thanks shes is picking up 26-27 mph after the 8th. I seen some 96.00 mph yesterday but blew the pass by missing 4th
Thanks man you definitely know how long Ive been fighting with this thing I am just finally happy to see it all come together
Moderator
26-27 mph gain from the 1/8 to ¼ is outstanding for a NA car. What gear ratio and tire size are you running?
John
John
John
4.56 with a 28*10.5 stiff sidewall hooiser slick
Very nice! I will be setting mine up alot like your.
I have mine picking up 25-26mph from 1/8-1/4. I plan to change my setup when the springtime (good weather) is about over. I will be swapping gears, tires and cam. I still haven't stepped up from the TR224 yet.
I also need more than a 4.10 gear and more tire. My best was 11.48@122.48 on a blown 1.69 60ft. Sure needed my normal 1.60. What sucked, I got one pass in before it started raining. Think I had a high 11.2-low 11.3 in it If I'd got another one. But there is lots of good weather racing coming up real soon!
