ran 13.8 @ 102....where should I be??
My first and only time to the track I ran 13.8 @ 102 w/ 2.22 60'. Considering my dyno #s, where do you think I should be? If I got some drag radials and a TQ arm could I get a 12.9?
The reason I ask is that a stock LS1 can usually get high 12s with a good 60'. I figure my HP is pretty close to a stock LS1.
What do you guys think??
Administrator
LS1. However, they are definitely possible with a M6 car, a 1.9 60,
and some serious rowing.
You're a long way off from 12.90's. Let's say you pick up some drag
radials and you cut a 1.80 60'. You're still looking at a 13.30 or so.
My suggestion would be to pick up some drag radials and add some
more power. You'll get your 12's.
Lt1
If you want to run 12's the weak link is the 7.5 ring and pinion.You have the power you just have to launch hard, save your money get a built rear end slicks and a little suspension 5k launch easily high 12's.
102 for an m6 seems a little low, especially for this time of year. Wait... he's got a '96-that's actually not bad. Get that 60' in the 1.8's and your lookin' at 13.3's -13'2s.
Lose some weight (like 300#'s and you'll see 12's) or add some power.
