My ET is way to high someone help!
I went to the track Wed Night it was around 91 degrees and 80% humidity (my 1st problem) I ran a 13.0 @ 111 MPH w/ 2.2 60 ft i think this is kinda slow since i dynoed at over 400 RWHP.
I am running a BBK Manifold which I'm sure was heatsoaked, and it was a slow night at the track so my runs were like 15 min apart.
I am running street tires but, next spring I'll be switchin ti Nitto DR's (trying to preserve my 10-bolt)
Any Tips? I'll probably go back one more time on these stupid street tires... what PSI should they be? any tips on launching my 6spd? any info/help is appreciated
Mods in Sig.
thanks!
Mods in Sig.
thanks!
400rwhp on 98 heads with a mild cam????thats really good#s...get some stickie tires that mph is good for low 12s...its not your intake i have a metal intake as well ive tested these heatsoak myths and there bs.....tires and practice...just dont get to ballsy and snap the 10bolt.....
400rwhp for a 111mph?
Either the dyno was wrong or your car weighs almost 4000 pounds with you in it. (111mph with a 4000 raceweight would actually take 384rwhp but I'm estimating you weren't making quite 400 in that heat and humidity)
As far as running the street tires, drop pressure to about 28 lbs., go around the water and do a decent burnout. Your 60 ft. has to drop, so do that and and with the streets let the clutch go at 2200 rpm, but almost ride it out for a milisecond and then mash it. Are you runnin stock gears? If so, then do what i said and see how you make out.
