How much does spinning hurt your mph???
Old 09-26-2008, 09:40 AM
dlove's Avatar
Originally Posted by Bitemark46
By spinning you're making the lenght of the track longer hence the higher mph. A similiar analogy would be at a stop sign during the rain and you stab the gas. Your speedo will hit 40-50mph but you're not going anywhere.
-Mark
im with mark.
spin, more mph less et
hook, less mph more et
Old 09-26-2008, 10:15 PM
1BADAIR's Avatar
I always gain a few mph if a spin a little
Old 09-27-2008, 07:42 AM
NastySSoo's Avatar
I have over 1,200 passes with an m6. Spinning hurts your mph period! With that being said, my best ets and mph came with an extremely small amount of spin, maybe half a revolution of the tire. This keeps the motor from bogging. I always heard people say spinning helps mph, but in my experience they are full of ****! My .02
Old 09-27-2008, 07:51 AM
blkbird_WS-6's Avatar
-Mark
But if the speedo shows 40-50mph your car might only be moving 25-30. At the track, it wouldn't be going by what your speedo says in your car, buy by how fast it's actually moving.
Old 09-27-2008, 09:31 AM
6 & 8 Second Club
mrdragster1970's Avatar
Well there we have it. 1200 pass' so he knows everything, we are all stupid & can't read a slip.
Lock the thread, no need to waste anymore time talking about it. Case closed.
Old 09-27-2008, 01:33 PM
NastySSoo's Avatar
Sorry to confuse you with the facts! Timeslips don't lie. I index raced it for four years and knew the car inside and out. I had a few dumbasses try to tell me spinning gave you more mph, but being at the track two or three times a week proved them wrong smartass!Maybe I should have said " in my car I lost mph when I spun"
Old 09-27-2008, 02:00 PM
bww3588's Avatar
your right, that is what you should have said insted of making yourself look like an ***.
last night i ran a 12.68 @114 with the burnout pushing my linelock so i never got the Hoosier QTP's hot at all. not even smoke. 1.94 60' spinning off the line.
then i got them nice and hot and ran a 12.39 @110mph with a dead hook and a 1.72 60'. remember, time slips dont lie smartass.
Old 09-27-2008, 02:55 PM
NastySSoo's Avatar
I guess you didn't take the time to read my post completely. If you deadhook you will lose some mph. Read what I said dickweed! I'm done with this post!
Old 09-27-2008, 03:30 PM
bww3588's Avatar
your not going to lose 4mph and gain 3 tenths compared to spinning moderately. not that this helps your case with posts like this one.......
and this.....
your exactly right, spinning hurts your MPH period.....keep shooting yourself in the foot.....
Old 09-27-2008, 05:09 PM
My 04 Goat's Avatar
I think people are trying to compare spinning MPH vs a run with a bog MPH.. On a clean launch you should get both mph and et, I would think
Old 09-27-2008, 06:05 PM
Restricted User
2001 Pewter WS6's Avatar
I think it makes a big difference if you spin a little like a 1.7 60' verses spinning alot and 2.2 60'.
Old 09-28-2008, 05:21 AM
  #32
darrensls1's Avatar
Smartest thing you said right there
Old 09-28-2008, 12:09 PM
  #33
8 Second 6 Speed Director
taner's Avatar
Location: windsor, ont. canada - Home of the fastest LT1 6spd.
i had to trim in front and behind my wheels for what i deemed acceptable tire clearance.
i don't believe a 26.5" mt will grow 1 inch in diameter, if that is what you meant. i usually factor .5 - .75" of growth maximum. this pretty much jives with the rpm on my data log to a tire size/gear ratio - calculator.
excellent mph! i honestly think you can get the mt street radials to hook! if you don't mind playing around with it to work.
Old 09-28-2008, 01:19 PM
  #34
InEEdSPEED's Avatar
The only time your going to gain mph with spinning depends on what you compare it with.
Listen people, if you compare a slight spin run with a dead hook run, you will probably gain mph. If you compare a slight spin run with a half/full spin run you will lose mph on the half/full spin run.
If you compare a slight spin run with a slight spin run, you probably wont pick up any mph. Its not that you GAIN mph because you spin, its that you GAIN ET/LOSE MPH when you hook.
Its logical sense, not hard, doesnt take a rocket scientist. You cant make a perfect mph run, then spin more and get a better time. Its all in reference and in the way you compare it.
Quick Reply: How much does spinning hurt your mph???
