120 octane unleaded ?
Wonder why they said it would be better for you when HTG and Motorsport 103 both have a higher octane?
"The detonation properties and burn rate of CSP are best I have found so far."
How do the detonation properties and burn rate differ than HTG? I'm curious since HTG has a far higher octane.
I found it very strange that the guy I spoke with at VP recommended C46 for a 15:1 9000 RPM engine. It has a motor octane of only 98.6.
As far as the unleadeds go, I've tried CSP, C10, and Motorsport 103. If I had to guess, Motorsport 103 may have worked best for my 422.
Reher Morrison did some testing and concluded that Mobil 1 did not protect high hp motors very well
PS - Are you racing at the Southern Shootout?
I hope to run at the Southern Shootout. At this point, I can't make any promises but I think I should be ready by then.
Colonel, I share your uncertainty. This season has been one big experiment that has eliminated accurate predictions. This week alone we are installing 9/16" head studs, 8740 main studs, a new coated bearing, new cam, new valve springs, new retainers and have changed engine clearances. We too are PLANNING to be in Baton Rouge!
As soon as the fuel starts burning the octane rating is pretty much irrelevant - at that point you are worried about the flame speed and probably the energy content of the fuel. The energy content isn't as big of a deal as it may sound since your fuel is not the limiting reagent - air is. You can always spray in more fuel - so you just spray in as much as you can react with the air.
The flame speed is probably the basis for alot of VP's recommendations - you will more than likely want a slower flame speed on a FI car due to the dense charge mixture - you would really need something like a cylinder pressure gauge and to correlate that with crankshaft degrees (and remember, the amount of force transmitted to the crank depends on the geometry of the rotating assembly at that moment). You have to balance the flame speed so it doesn't burn to fast - so you get a tremendous instantaneous release (which would be pretty hard on parts and not to efficient) - but if you wait to long you either loose part of the burn, or you get so far down in the stroke that most of the pressure is wasted due to the r/s angle.
http://www.cpchem.com/fuels/products/racingfuels.asp
