4th gen bbc guys come inside!!help!!!
PLEASE POST UP SOME PICS WOULD LIKE TO SEE HOW EVERY ONE MOUNTED EVERYTHING (dry sump,vac pump,ext!!!) thanks for the time guys...warren.
With a single quad setup, the guys on here had to notch the cowl back to the windshield and STILL the can't get to the rear float adjuster.
It will take ALOT of cutting and fab work to go to a tunnel ram.
Also, what kind of big block do you plan on running? There are alot of guys here going quite fast with only one carb on a 582" or 632".
Good luck running two carbs, especially on a taller intake!
my carb sits about 1" under the cowl even with a double cross bar nitrous plate thats about 1" tall
www.fquick.com/nubby1
