Benifits of front sway bar removed??
8 second mod
Anything on this would be nice,
I pulled mine yesterday, I know its 15lbs off the nose, Pro,I know it frees the front wheels for travle,Pro
Makes the car dive a little around corners,Con
Anything ealse?
Thanks
Anything ealse?
Thanks
Re: Benifits of front sway bar removed??
Nope, nothing much else to my knowledge. The biggest deal is the front suspension travel, so if you didn't care about the weight you could just unhook it from the lower a arms before you ran at the track.
it decouples the front wheels and removes the weight up front allowing better weight transfer.
LS1TECH Sponsor
Can you get the same effect by just undoing one end, or do both ends need to be loose?
It would not be that hard to unbolt one end at the track as I change tires already.
Thanks.
Thanks.
8 second mod
I pulled the hole thing off including brackets in about 15 min, And i have all types of intercooler pipe in the way. Very easy mod, and if your diconecting it anyway, mine as well loose 15 lbs while your at it!
With my mods below, how much should I expect to gain in the 1/8th by removing the sway bar?
I ran 8.72 @82.4 (temps in the upper 80's) w/ 2.11 60'. I need to cut that 60' a little more. I'm running Nitto 555's..no DR's.
Does removing the sway bar make the car loose at the top end of the track? If not i wil be removin min wednesday before i go to the track.
