Drag Racing Tech
BBC into 4th gen hedder options?
Old Nov 28, 2008 | 12:41 PM
BadBoo79's Avatar
Default BBC into 4th gen hedder options?
I currently run the Hooker 2455 hedders on my BBC, but I am interested to see if any other non-custom hedders would work as well. The Comp series have worked fine, but the primaries are small, so I'd be interested to see what sort of gains a larger (either 2.125" or 2.25") primary would offer.
Old Nov 28, 2008 | 01:04 PM
87Lt1Monte's Avatar
to squeeze all that in there with a k frame w/ motor mounts I would love to find something non custom!
Old Nov 28, 2008 | 02:13 PM
Fast_94_Z's Avatar
what k member are you running? are you running motor plates? im not much help since ill be running a turbo with custom headers.
Old Nov 28, 2008 | 02:53 PM
snipers's Avatar
try this :
http://www.lemonsheaders.com/main.htm
Old Nov 28, 2008 | 03:14 PM
JUICED96Z's Avatar
Also might check out Ed Quay.
Old Nov 28, 2008 | 03:51 PM
87Lt1Monte's Avatar
Yea you bend that nice 1200$ header up you will be a MAD mother.. bend that 180$ header up.. who cares ..
Old Nov 28, 2008 | 04:23 PM
BadBoo79's Avatar
I have a PA racing K-member with stock mounts and a front motor plate:
I also have clearanced the firewall for additional room on the passenger side:
I agreed, smashing a set of $169 hedders is a whole lot better than $1100 Lemmons!
I did contact Ed Quay, so we'll see what they say.
No one else knows of any bigger tube Hooker or Hedmans that may work?
Old Nov 29, 2008 | 08:38 AM
Fast_94_Z's Avatar
i think if you put a midplate in the back and did away with the stock mounts you could fit almost anything in there.
Old Nov 29, 2008 | 10:18 AM
Steve Burger's Avatar
LS1TECH Sponsor
Agree, use a mid plate and get rid of the stock mounts. That will clear up a lot of room.
I have pics of our mid plate setup here:
http://www.burkhartchassis.com/steveberger.html
we hang the mid plate and do not get in the way of the collectors.
Old Nov 29, 2008 | 11:19 AM
MrPotatoeHead's Avatar
http://store.summitracing.com/partde...5&autoview=sku
Old Nov 29, 2008 | 12:03 PM
BadBoo79's Avatar
Originally Posted by MrPotatoeHead
Correct, those work well and are what I run now. I'd like something larger than a 2" primary though.
Old Nov 29, 2008 | 03:16 PM
87Lt1Monte's Avatar
If your going to do all that, you should just get the headers that lemmons make . I know on their site they say a BMR K Frame w/ mounts can run that header .. Changing to a Midplate does not help there is no other headers close enough to run on the car .. to my knowledge atleast.
Old Nov 29, 2008 | 04:05 PM
ty_ty13's Avatar
7 Second Club
after you get your car sorted out just take it to a fabricator and have him make a set...
no matter what header you buy off the shelf you will have to hammer and bend it.... im not interrested in doing that to a 1400$ header.... if i pay that it better fit without any bullshit....
i have the 2455 on mine also until i make sure the wheel stands arent *much of an issue...
