Vengeance EFI Hot Street 2009 Class Rules!!
VENGEANCE EFI HOT STREET
2009 Rules
Presented by: ORSCA
www.OutlawRacing.com
Sponsored by: Vengeance Racing
www.VengeanceRD.com
ENTRY:
$25.00 Registration Fee
$100.00 Annual Fee (ORSCA Membership)
PURSE:
$350.00 FIRST PLACE
$200.00 SECOND PLACE
$100.00 THIRD PLACE
FORMAT:
1/8 Mile in conjunction with all ORSCA events
Pro Tree
Heads Up Racing
GENERAL OVERVIEW:
ORSCA “EFI Hot Street” is a class designed for LATE MODEL STREET CARS and TRUCKS equipped with DOT Legal street tires or Drag Radials. EFI Hot Street entries are permitted EFI Naturally Aspirated/nitrous equipped/supercharged/ or turbo charged small block applications up to 427 cubic inches. This class is designed for stock bodied, stock appearing vehicles driven on the street. EFI Hot Street races will be conducted at all ORSCA drag racing events (see race schedule). Each event, the winner of the class will be required to carry an additional 25lbs for the next event, and the runner up will be required to carry an additional 10lbs. This weight adder will be cumulative through the racing season, adding up each event. At the conclusion of the season all racer weights will be set to zero.
REQUIREMENTS:
· Valid Drivers License- MUST match driver of vehicle
· Valid Registration- MUST match vehicle entered to race
· Valid Insurance-MUST match vehicle/driver
· All entries must be self starting with on board starter
· All lights on vehicle must be functional. IE Headlights/taillights/brake lights/turn signals/hazard lights
· Driver/vehicle must complete 25 mile cruise unassisted in the timeframe set fourth by ORSCA. Any vehicle that does not complete the cruise will NOT be allowed to race
· Vehicles hood is to remain closed after returning from 25 mile cruise. Any racer found opening his hood for any reason will be disqualified immediately.
25 MILE CRUISE:
There will be a 25 mile supervised cruise on highway and city streets prior to competition, limited to those vehicles who have passed tech inspection. An escort will supervise the cruise in accordance with local laws and ordinances. Each competitor and crew will be on their own recognizance during the cruise and bear full responsibility of their actions as they would on city streets. Please be safe and follow all traffic laws during the cruise.
Cruise is mandatory in the time allotted for competition. Any vehicle unable to complete the cruise under its own power, within the allotted time, will be disqualified from racing. Any vehicle that falls behind the trailing escort will be disqualified.
VEHICLES PERMITTED:
1985 to current
EFI ONLY
V8
MINIMUM WEIGHT-3300lbs (Including Driver)
Vehicles will be weighed after each pass during eliminations. Any entry not meeting the base weight requirements will be disqualified.
WEIGHT BREAKS:
· Manual Transmissions deduct 100lbs from base weight
· Nitrous powered cars deduct 50lbs from base weight
· Non Intercooled/non aftercooled supercharger systems deduct 50lbs from base weight
· Less than 370 cubic inches deduct 50lbs from base weight
· Over 404 cubic inches ADD 50lbs to base weight
· Naturally Aspirated combinations under 404 cubic inches deduct 100lbs from base weight
· Naturally Aspirated combinations over 404 cubic inches deduct 50lbs from base weight
SAFETY:
It is the participants responsibility to familiarize oneself with the class requirements as found in the 2009 ORSCA rulebook AND the safety requirements as found in the 2009 NHRA rulebook. The participant agrees that he/she bears the ultimate responsibility at all times to ensure the safety of participants vehicle and to ensure that he/she complies with all applicable ORSCA/NHRA rules.
ORSCA REQUIRED DECALS:
All participants will be required to display ORSCA official windshield decal
All participants will be required to display Vengeance Racing decal.. Placement TBD prior to first scheduled event
EXTERIOR OF VEHICLE:
· Vehicle must have full body
· Aftermarket body kits accepted as long as they are for aesthetics only
· Aftermarket hoods allowed
· Cowl Hoods limited to 4” cowl
· Pin on Hoods permitted
· Absolutely NO lexan
· Stock front fenders/front clip. NO removable one piece setups
· Vehicle must have driver/passenger exterior mirrors if originally equipped
INTERIOR OF VEHICLE:
· Interior of vehicle must maintain “stock appearance”
· Factory gauge cluster intact and functioning
· Door panels/Interior trim in place where applicable
· Stock pedals/mounting location required
· Aftermarket steering columns prohibited
· Removable steering wheels prohibited
· Aftermarket steering wheels permitted. MUST bolt to column
· Factory or aftermarket headliner required
· Aftermarket gauges permitted
· Rear seat delete permitted
CHASSIS/FRAME/SUSPENSION:
Stock type suspension may utilize aftermarket, direct replacement type suspension components including aftermarket replacement shocks/springs (In factory location), leaf springs, and/or control arms. All stock type 3 or 4 link suspensions must maintain stock lateral angles and attachment points, but may be moved up or down on rear axle. Aftermarket torque arms permitted, if OEM equipped with torque arm. Attachment point of torque arm on body or frame may be relocated, but OEM attachment point at rear end must be retained. Aftermarket leaf spring kits permitted.
· Full frame as manufactured
· Engine in factory location
· No motor plates
· Solid motor mounts accepted
· Stock style suspension using stock mounting locations. No deviations
· Coil overs accepted
· Subframe connectors accepted
· Stock wheelbase
· No “Racing” 4 Link/backhalf cars permitted
· No wheelie bars
· Mini tubs accepted
· Factory firewall in OE location required
· Engine location may not be altered from stock
· No part of engine or heads may contact firewall
· Aftermarket rearends using factory mounting points permitted
ENGINE: CYLINDER HEADS- General Guidelines
· Only commercially available/mass produced cast aluminum or cast iron cylinder heads permitted
· Two valves per cylinder unless otherwise produced by OEM manufacturer (3 valve/4 valve Modular)
· Billet, one off, custom and/or fabricated heads prohibited
· Cylinder heads must be overhead valve single spark plug per cylinder design
· External modifications prohibited in port areas
· Spark plug placement and depth must remain stock
· Welding/Epoxy any part of the cylinder head prohibited
· Hand and CNC ported permitted
· Milling of cylinder heads permitted
· Max Intake Runner volume not to exceed 245cc (GM L92/LS7 excluded from this rule)
PERMITTED CYLINDER HEAD LIST:
These are the only permitted cylinder heads for competition in this category. If your cylinder head is not on the list, it is prohibited.
Small Block FORD- Standard Intake Runner & Exhaust Port versions only
· FORD OEM 4.6L 2/3/4valve,5.0,5.8 Cast Iron and Aluminum heads
· FRPP GT-40/GT-40P/GT-40X/GT-40Y
· FRPP “Z” Part# M-6049-Z304
· Edelbrock Performer & Performer RPM
· Edelbrock Victor Jr (20* Version only)
· Trickflow Twisted Wedge, Twisted Wedge R, TFS Hi Port & Track Heat (Non R)
· Brodix ST 5.0 Aluminum, PT# ST 5/0, ST 5.0R
· Brodix TI & T1X
· Holley 5.0 Pt#300-573,574,575,577,578,579
· World Products Roush 180 & Windsor Jr Pt# 53030,23030
· AFR 165/185/205
World Products Roush 200 & Windsor Sr Pt#53040
· DART Pro I 170cc/195 As Cast/215CNC
· Canfield 20* 197cc Pt# 20-450-20-475
· RHS 180cc &200cc Iron and aluminum
Small Block Chevrolet-Standard Intake Runner & Exhaust Port Versions Only
· GM & Chevrolet Factory Small Block Heads, Including LS1/LT4, etc
· Edelbrock Performer LS1/LPE/Performer RPM/E-Tec 170 &200cc
· Edelbrock Victor Jr, 23* Standard Runner/Exhaust Port only
· AFR LS1 205/225
· AFR 180/190/195/210/220 Standard Runner/Exhaust Port only
· Brodix RR180,RR200-8&-10 Standard
· Dart Iron Eagle 165cc thru 215cc
· Dart Pro 1 200 thru215cc
· ET Performance LS Series 5.3/LS/LS7
· Canfield 23-500 23*, 23-600(220cc)
TrickFlow 215cc R Series & Duttweiller 23*
· TrickFlow 215/225/235/245 CNC
· TrickFlow 220 As Cast
· World Products S/R Torquer, Sportsman II 200cc
· World Products Motown 205cc, 220cc
· C5R/C5R Style Heads Prohibited
Chrysler Small Block:
· Stock Factory OEM Iron or OEM Aluminum 318/340/360 Cylinder Heads
· Edelbrock Performer RPM & RPM 340
· Brodix B1-Ba (Not MC)
· Mopar Performance W2
· Indy 360-2 Oval port only (not 360-1 Rectangular port)
AMC Small Block:
· Edelbrock Performance RPM
· AMC Factory OEM Iron & Aluminum
ENGINE:Block
· OEM and aftermarket blocks permitted
· Engine blocks must be mass produced and available for purchase by any individual
· Aluminum and steel blocks permitted
TRANSMISSION:
· Factory Mass Production style 3/4/5/6 speed transmissions accepted
· No clutchless manuals allowed
· Manual cars must use OE STYLE clutch/flywheel
· Twin disk clutches permitted if readily available in the aftermarket
· No Transbrakes/Two steps/stutter boxes/electronic devices allowed
· Pneumatic/electric/hydraulic etc shifters prohibited
· Proshifting/faceplating manual transmissions prohibited
· Lenko/Liberty/Powerglides Prohibited
EXHAUST:
· All vehicles must have full exhaust including mufflers
· Exhaust must exit the vehicle no less than 12” from centerline of rear axle
· No collector style mufflers permitted
· Exhaust size limited to 1 7/8 primary and 3” collector
· 3” maximum exhaust pipe from header to mufflers
· Turbocharged engines may use a single 4” maximum exhaust from the turbo housing, but it must split to dual 3” prior to the driver seat area
POWER ADDERS:
· Turbos/Nitrous/Superchargers allowed
· Single Power Addder Only
· Power Adders cannot be used in conjunction with one another. The only exception is twin turbo systems not exceeding 57mm each
· Meth Injection/Alcohol Prohibited
TURBOS:
· Turbocharger must be of conventional impeller and housing design and type.
· Turbocharger is limited to a maximum size of 76mm/2.755 Inducer wheel diameter at the point where leading edge of the compressor wheel meets the inlet housing.
· Inlet housing is permitted a maximum inlet diameter of 2.814” where the leading edge of the compressor wheel meets the housing. All air entering turbocharger must pass thru turbocharger inlet
· Injection of any liquid/gas or other substance into the inlet or exhaust housing prohibited
· Turbocharger compressor wheel must be constructed of cast or billet aluminum
· Exotic material wheels prohibited
· The tips of the impeller wheel may not be stepped, cut down or notched to meet impeller tip to tip dimension
· T4 Inlet Flange Only
· T4 Flange must be T4 casted housing. No studded or altered T6 Housing permitted
· No modifications to turbo or flange in anyway
· Intercoolers allowed. Must mount in engine bay of vehicle
· No intercoolers/aftercoolers allowed in passenger compartment
TWIN TURBOS:
· Turbo charger must be of conventional impeller and housing design and type
· Turbocharger is limited to a maximum size of 57mm
· All air entering turbocharger must pass thru turbo inlet
· Injection of any liquid/gas or any other substance into the inlet or exhaust housing prohibited
· Turbo compressor wheel must be constructed of cast or billet aluminum.
· Tips of impeller wheel may not be stepped, cutdown or notched to meet impeller tip to tip dimension
· T3 Flange-Must be T3 casted housing, no studded or altered T4 housings
· No Hybrid turbos
· Intercoolers/aftercoolers permitted in engine bay only
SUPERCHARGERS: Permitted superchargers are restricted to accepted commercially available, standard, mass produced systems, utilizing the factory style belt drive. Internals of supercharger units may not be modified from standard, mass produced units. Injection of any liquid/gas or any other substance into the supercharger prohibited. All supercharger systems must utilize stock, as provided supercharger head unit
· Cog systems prohibited
· 6 and 8 rib belt drives accepted(10rib if OE equipped)
· Superchargers must be commercially available
· Head units may not be altered in ANY way including removal or Manufacturers “Tag”
· Intercoolers allowed. Must mount in engine compartment
· No intercoolers/aftercoolers permitted in passenger comparment
Maximum blower size options:
· Vortech T Trim
· ProCharger D1SC
· Paxton Novi 1200
· Powerdyne and/or SVO/FRPP Street System
· Eaton 112
· Kenne Bell 2.8
· Whipple 2.3
NITROUS:
· Single stage Nitrous Only
· Purge Kits permitted
· Purge must exit engine compartment
· Nitrous Pill limited to 99 Orifice-Stock Unmodified
· One Bottle in vehicle-10lbs max
· Nitrous Push systems prohibited
· NANO systems prohibited
· Progressive controllers permitted
TIRES/WHEELS:
· DOT Tires Only
· ET Drags/ET Streets/Bias Ply tired prohibited
· Tires must be on vehicle for 25 mile cruise AND race
· Spindle Mount front wheels prohibited
· Max Rear Tire Diameter: 28”/Tread width: 9.5”/Circumference 87” (275/60/15 Mickey Thompson Drag Radial)
ENGINE MANAGEMENT:
· No Laptops or datalogging equipment in car during race
· Speed Density permitted for all combinations
· OEM Engine control computer MUST be functional
· Plug In chips and EEC computer Add ons permitted for FORD EEC IV or FORD EEC V ONLY
· EFI Add ons: If your computer is not on the list it is prohibited
· FRPP Extender
· FRPP EPEC
· Anderson FORD PMS
· Autologic Plug In EEC Chip
· SuperChips Plug in EEC Chip
· HyperChip Plug In EEC Chip
· Diablo Plug In EEC Chip
· EEC Tuner
· SCT XCalibrator & XCAL2
· Diablo Predator
FUEL:
· No “racing fuel” permitted
· No octane additive allowed
· No fuel can be added after 25 mile cruise
· Vehicle must have the ability to provide sample of fuel without teardown for inspection
· Spec Fuel will be VP100 Street Blaze or equivalent
INTAKE MANIFOLD:
· Commercially available, mass produced intake manifolds permitted
· Any height spacer permitted between EFI upper/lower intakes only
· All runners must be completely separated from each other runner
· Spacer or gasket must not create “plenum” or any other means for air to pass between runners
· Porting permitted for EFI Upper/Lower intake manifolds
· Upper EFI Manifold may be ported, but may not be cut, modified or welded.
· Runners may not be shortened
· Welding/Epoxy prohibited
· Custom sheet metal intakes prohibited
THROTTLEBODY:
· ONLY mass produced, commercially available throttlebodies permitted
· Single throttlebody only
FUEL INJECTORS:
· Any type /size fuel injector permitted
· Maximum of 8 injectors located in stock location
AIR CLEANER:
· Commercially available, mass produced automotive air cleaner required
· All incoming air MUST pass thru air cleaner
I never understand why classes like these don't allow lexan when they DO enforce a weight minimum. I see that speedglass $399 rear window that is available, and I do believe you will be seing that on a lot of street cars in the future.
Percys Speed glass is pretty new to the market.... When you cruise thru town exactly how many cars do you see with Lexan windows?
Alot of the rules might not make sense, but they are there to eliminate RACE cars and TRY to keep this somewhat of a STREET car class...
It would be easy for an Outlaw car to add 300lbs and come race in this class if all of these crazy rules were not put into place.
Hey Ron, can you clairfy this for me, taken from above:
·" Max Intake Runner volume not to exceed 245cc (GM L92/LS7 excluded from this rule)"
· AFR LS1 205/225
I take that as it means you can run teh L92, but under the listed heads, it is not SPECIFICALLY listed, unless you consider the "GM & Chevrolet Factory Small Block Heads, Including LS1/LT4, etc" as listing the head under that line. Is that correct? And if so, does that mean, LS6 is included as well? Just curious., thanks
· AFR LS1 205/225
· AFR LS1 205/225
· AFR LS1 205/225
I take it as any GM production casting except for C5R.
