Drag Racing Tech
Evap Delete?
Old Jan 7, 2009 | 06:00 PM
XpEdItIoUs's Avatar
Default Evap Delete?
I removed my evap completly including the resinator, do i just let it vent to the outside?
Old Jan 7, 2009 | 08:01 PM
nemss1's Avatar
yes. stick a filter on tho to keep dust out of the tank
Old Jan 7, 2009 | 09:39 PM
XpEdItIoUs's Avatar
Cool so just stick a hose on the fittting off the tank and add a filter?
Old Jan 7, 2009 | 09:57 PM
nemss1's Avatar
ya u could do that. i just left the hose on mine and cut the hose on the EVAP canister side and left a lil hose and slid a filter in
Old Jan 7, 2009 | 10:50 PM
XpEdItIoUs's Avatar
Thanks, Wouldn't the fumes be dangerous? I keep my car in the garage wouldn't that be a fire hazzard?
Old Jan 8, 2009 | 01:25 AM
nemss1's Avatar
i cant answer this with a for sure answer but i dont smell any fumes frm my car and a couple people on here have also have this setup
Old Jan 8, 2009 | 04:40 AM
JL ws-6's Avatar
Race your car!
I pulled all mine off and haven't had any fumes from it.
my take on it is this: if you still have a muffler under the tank, you're gonna have more of an issue with fumes then someone with an exhaust like mine that dumps out the sides in front of the tires, because the heat from the muffler is gonna heat the tank, heat the fuel, and then cause pressure in the tank, and more fumes.
If you street drive alot, I think it would be a problem, for a track car it doesn't seem to be an issue.
I did put a little filter on the end of the line, I just cut the clip on fitting off my evap line as well, and slid a cheap autozone filter on there, and put some silicone on it to hold the filter on so it won't slide off. It's been that way for a whole season and I have yet to smell anything, see any fuel leak from it, etc.etc.
This is a race car though, so keep that in mind.
Old Jan 8, 2009 | 09:40 AM
XpEdItIoUs's Avatar
Mines a limited street car, More of a weekend warrior. I was just wondering if anyones garage has blown up by doing this lol.
Old Jan 8, 2009 | 09:42 AM
JL ws-6's Avatar
Race your car!
I'd like to hope not.
Old Jan 8, 2009 | 10:33 AM
Magic Man's Avatar
Wouldn't be any different than on older cars with vented caps.Since the valve up front would be gone is there a code for this?
Old Jan 8, 2009 | 10:36 AM
JL ws-6's Avatar
Race your car!
yup, throws a code.
Old Jan 8, 2009 | 10:41 AM
XpEdItIoUs's Avatar
I got my codes disabled.
Old Feb 4, 2009 | 12:28 AM
Soul TKR's Avatar
anybody got a pic of what they did?
I had my codes disabled and basically just pulled off the hardline/hose from the intake manifold to the evap canister... then put a plug on the nipple of the intake manifold, and left the evap canister dangling... nothing else done to it... here's the hose i pulled off...
am I ok leaving it like it is, or do I need to do something else to it? I was told I could pull that whole rubber hose with the evap canister off, and be done with it...
I'm starting to wonder if this is what is causing my new found problem with "sputtering" at the high rpm range... which all started after my new injector install, volant cai install, and evap delete...
Old Feb 4, 2009 | 01:04 AM
XpEdItIoUs's Avatar
I pulled everything completly off, and left a filter on the end of the hose that went from the tank to the charcoal canister.
Old Feb 4, 2009 | 02:26 AM
nemss1's Avatar
pulled mine off completely also, pulled the purge solenoid (in pics), all hoses, metal line to the back of the car and EVAP charcoal canister. havent had any probs after !EVAP
Old Feb 4, 2009 | 01:02 PM
Soul TKR's Avatar
I guess i'm having a hard time picturing where you guys are putting these filters... am I in danger if I don't have a filter of something getting clogged up?
Old Feb 4, 2009 | 01:59 PM
XpEdItIoUs's Avatar
You might have some trashed get inside your tank if you remove the canister.
Old Feb 4, 2009 | 02:33 PM
LS1SpeedAddict's Avatar
where is the canister? near the tank?
Old Feb 4, 2009 | 03:33 PM
XpEdItIoUs's Avatar
behind the driver side rear tire, there will be a plactic cover covering it.
Old Feb 4, 2009 | 05:29 PM
Soul TKR's Avatar
oh... so this thing I circled in yellow is not the canister?
