Drag Racing Tech
Bump stops
Old Jan 9, 2009 | 06:10 PM
DADDY&GIRL93TA's Avatar
Question Bump stops
We have the weld pro stars 15x10 on a 275 /50/15 MT DR. Question is took the wheels off and noticed a slight rub on the inside of the tire in just one spot. Figuring it must be loading or unloading the car at the track. Can i lose the bump stops with out hurting anything at all.Did a seach and came up with alot of yes and nos. And it almost looks to me with them on if the car would get sideways bad it would almost get into the wheels. Shocks were on the QA1s all 4 corners. Stock bolt on motor. Thanks gang
Old Jan 9, 2009 | 06:36 PM
jmill96Z's Avatar
I cut mine off for 325's. No problems here.
Old Jan 9, 2009 | 06:49 PM
3rdgen92maro's Avatar
yup you can cut them off it wont hurt anything
Old Jan 9, 2009 | 07:25 PM
xpndbl3's Avatar
as long as you're not loading the car down with 4 people and a trunk full of luggage you'll be fine even daily driving it.
Old Jan 9, 2009 | 08:17 PM
cbra-klla's Avatar
they unbolt or do you have to cut em??
Old Jan 9, 2009 | 08:24 PM
xpndbl3's Avatar
while they do unbolt, the bracket will still stick out the same amount, so typically you cut them out and weld in flat 16 gauge steel or something similar.
Old Jan 9, 2009 | 09:06 PM
sweetbmxrider's Avatar
cut em and paint em with undercoat.
Old Jan 10, 2009 | 06:40 AM
blk99camaro's Avatar
Can you guys post pics of how much you cut out? Im in the same boat as him....
Old Jan 10, 2009 | 08:53 AM
ndfrsd6's Avatar
one of the first things to go on mine ...
Old Jan 10, 2009 | 09:20 AM
all the way to the inner fender. might have to hammer it in a little bit and clean it up some so its not a sharp leading edge.
Old Jan 10, 2009 | 01:26 PM
Taubr Unit's Avatar
interested also, got pics?
Old Jan 10, 2009 | 09:09 PM
1999TransamWs6's Avatar
Cut them out no problems at all.
Old Jan 10, 2009 | 09:12 PM
xpndbl3's Avatar
come look at my car and i'll show you how they look all smoothed out. Just cut out the entire section and weld in flat 16 gauge steel instead and if you cut enough out you can weld the steel against the coil spring for the most clearance possible out of those fat springs.
Old Jan 11, 2009 | 10:19 PM
nemss1's Avatar
do you cut the sheet metal around the wheelwell or just right above the bracket???
Old Jan 12, 2009 | 07:48 AM
mad_steve's Avatar
bump stops are usually one of the first things to go.
Old Jan 12, 2009 | 01:43 PM
1BADAIR's Avatar
hehe just lower the car like me. mine sit inside the wheel and are not close to anything
Old Jan 13, 2009 | 07:38 AM
tomz28's Avatar
^^^^ but if you lift the car not by the rear end does it hit the rim. because that what was going on with me. i cut mine off
my car will almost hit the gas tank with out them on a hard dig run anyone else have this
Old Jan 13, 2009 | 08:26 AM
1BADAIR's Avatar
no, mine don't hit. stock width , 15x10 7.5 without spacers
Old Jan 13, 2009 | 10:08 AM
the_merv's Avatar
Veteran: Air Force
I think I have mine out.. I don't remember, it's been a minute since I looked at them..lol
