Fastest Time of Drag Radials?
the tires they use is 325/50/15. There are only 1-2 organizations that let you use the huge 315/60/15
most of those cars are setup with powerglides, specific suspension, and really odd power curves to keep the tires from going away
But these motors are making well into the 1200hp range if not more. I know of making making almost 1700hp on the dyno. I also know of 2 cars that have gone 170mph
-----more realisically though, if you learn to drive on the tires you can get them to get you into the 10s pretty easily. After that it becomes a combination of luck and tuning
i'm not saying you cant do it, just takes a lot of practice and patience
The 315/60R15 BFG DRs will give me better traction and probably better streetability then say a 26/11.5/17 ET Street, though, right?
thanks
10.87 et
134.7 mph
1.69 60ft.
I had to peddle the car more then expected even trying to roll into the throttle. I have no plans to try racing on them again.
The BFG's that everyone runs quick on are alot softer sidewall and therefore hook much better,but wear out quickly.
Larry
SDB
