Drag Racing Tech
1SC stripper build
Old May 21, 2012 | 12:53 PM
  #261
jimbos'ss's Avatar
awesome build!
Old Jun 30, 2012 | 12:42 AM
  #262
Heyfred's Avatar
I can not believe the car has been down for 9 months.
Rear brake install is done. Any 15" wheel should fit with no issues.
Brake line routing:
Above rearend.
Took the car out for a shake down, new brakes and supension changes. Wow, what a difference.
Drawings are done for my new fuel tank, which works with evap, goes in the stock location, holds 10 gallons of fuel instead of 16 gallons, uses stock fuel pump bucket and fills with stock filler neck.
Old Jun 30, 2012 | 02:48 PM
  #263
wws699's Avatar
Killer Look!
Old Jun 30, 2012 | 07:01 PM
  #264
98 grmrpr's Avatar
Lookining good man!
Just some food for thought instead of the everfaithfull p- clip. I hate to say it..... but have you seen the brakeline clamps from that hushed chinese company Aeroflow?? They are nice and tidy a 2 piece billet clamp and bolt and nut, I would just do away with the bolt and nut, and nutcert it to the body!
Just a thought.
Old Jun 30, 2012 | 09:29 PM
  #265
NVUSZ28's Avatar
What did you do with the 17' narrowed rims?
Old Jun 30, 2012 | 10:06 PM
  #266
LongIsland63SS409's Avatar
Brake line routing:
Above rearend.
Nice stance!
Mike
Old Jun 30, 2012 | 11:23 PM
  #267
BSmiff's Avatar
Good stuff man. PM me next time youre rollin to Bremerton Raceway. I live in Silverdale while my ship is here.
Old Jul 5, 2012 | 05:48 PM
  #268
Heyfred's Avatar
Almost out of things to do.
Right rear sat 1" low, so I made 1' spacer to go under the spring perch on the rearend. Suspension ajust evenly now.
Finested the front of the rear inner fender wells for more clearance with the bigger tire. Had 275 on and went to 295.
Next thing to do, modify the panhard bar mount on the rearend so the panhard bar is level at ride height.
Took the car out for a 50 mile shake down drive, no issues.
Ordered some M/T S/R 28X12.00R15LT tires for driving around town or long trips. Will order the same rear rims to mount them on.
Old Jul 6, 2012 | 04:52 PM
  #269
Heyfred's Avatar
Had the drag radials dismounted and mounted the M/T S/R 28x12x15 tires that came today.
Ordered another set of rims and they are 3 weeks out.
Old Jul 6, 2012 | 07:37 PM
  #270
studderin's Avatar
why the switch to thous tires?
Old Jul 6, 2012 | 08:05 PM
  #271
Heyfred's Avatar
I will have a set of for going to the strip and a set for going to dinner or long trips.
Old Jul 10, 2012 | 09:02 PM
  #272
Heyfred's Avatar
Panhard bar mount has been modified so it sets level at ride height. Used a piece of .125"x2"x2" tubing to make the new bracket out of.
Here it what the stock bracket looked like.
Cut part of the bracket away, took a torch, heated and dollied flat so I could use the material as an end cap.
Layed out the needed diamensions, used a hole saw to cut the large radiuses and a 4" cut off wheel to remove metal as needed.
Used the original bolt hole to hold the new bracket in place until tacked.
All welded up and ready for paint.
Shorted both bushings .0625" to fit in the ID of the tubing.
Next thing, shorten the swaybar end links so I have more adjustment to get the arms level.
Old Jul 11, 2012 | 05:32 PM
  #273
Heyfred's Avatar
I am out of things to do. In 2 weeks (waiting on new rims to show up for drag radials), will be at the track fine tuning the suspension to see what the ole girl will do.
Today, machined up a spacer for the panhard mount and shortened up the swaybar end links, so it can be adjusted level at ride height.
The spacer may be overkill, but it is cheap insurance to help prevent flexing.
Old Jul 12, 2012 | 01:27 AM
  #274
98 grmrpr's Avatar
Nice job man!! I need to do a similar thing with my swaybar, as I removed the body mount and I'm not sure what Chuck is doing with the mount on the housing so I have hung off on the job.
Im curious as to what benefits there is in bringing the panhard rod level?
I will not be running the top brace, im not even sure what it is supposed to do!
Old Jul 12, 2012 | 02:00 AM
  #275
Heyfred's Avatar
Keeps the rearend centered in the car at the particular ride height as the suspension movement changes.
Old Jul 12, 2012 | 02:06 AM
  #276
98 grmrpr's Avatar
Yeah cool, I know it centres the diff! But what is the benefit in it being level?
Old Jul 12, 2012 | 02:15 AM
  #277
Heyfred's Avatar
The higher or lower on the radius the arm is, causes the rearend to shift as suspension moves up or down.
Old Jul 17, 2012 | 09:24 PM
  #278
JustJewIt's Avatar
"Measure twice, cut once." "Do it right the first time." "Quality over quantity." "Pay attention to detail."
These are the sayings that I think of after reading this thread. Car looks awesome. Can't wait to see more updates and watch it go down the track.
Old Jul 18, 2012 | 12:07 AM
  #279
Ryan K's Avatar
Pathological Modifier
Any chance of coming out this weekend? I'll be at Bremerton Friday and Saturday.
Ryan
Old Jul 19, 2012 | 12:18 AM
  #280
wws699's Avatar
he took a bike ride to SD
