Drag Racing Tech
1SC stripper build
Old Aug 24, 2012 | 07:50 PM
  #301
Heyfred's Avatar
Car is back together and ready to go racing tomorrow night. Should pick up ET, 60ft and mph with the spring and rear gear changes. Randy will be at wheel.
Old Aug 25, 2012 | 07:48 PM
  #302
Ryan K's Avatar
Pathological Modifier
What gears did you put in it?
Old Aug 26, 2012 | 04:11 AM
  #303
Nitroused383's Avatar
Why not drive your own car? We are talking about an 11 second car here not a top fueler.
Old Aug 26, 2012 | 08:50 PM
  #304
1nastyss's Avatar
, was wondering the same thing, but definently a killer car, really nice build.
Old Aug 26, 2012 | 10:06 PM
  #305
Heyfred's Avatar
Randy cut an .000 light first pass with the suspension changes and was given a momento for doing so.
The car slowed down the with the gear change. Going to have to make some decisions over the winter on which direction to go with.
*Keep current 243 heads, LS6 intake manifold, change rear gear to what works well and be a consistant 11.7 car.
Or
*Replace intake and heads to pick up some hp/tq.
Or
*Replace entire engine with LS3 based 416.
The car is put away, till I make a decision on which direction to go.
I need to see what the car is doing to learn setup and my plans (dream)for the future are bigger than what you see. It will be a team effort.
Old Aug 27, 2012 | 11:52 AM
  #306
fex77k's Avatar
Originally Posted by Heyfred
Randy cut an .000 light first pass . . . . . . . . .
That's why he drove it. Me and my brother both drive his 68. Nice lights.
Old Aug 27, 2012 | 08:54 PM
  #307
wws699's Avatar
In the rear end? Or the transmission
Think he went from 4:71 to 3:90 in the rear.
What 1st and 2nd gear ratio did you put in that transmission?
Old Sep 4, 2012 | 08:52 PM
  #308
54inches's Avatar
Great build! I am looking for a 1SC to do something similar.
Looks like thee were only a few haters. lol
Can't wait for the next 2 years!
Old Sep 26, 2012 | 09:46 PM
  #309
wws699's Avatar
Old Sep 30, 2012 | 10:42 PM
  #310
Heyfred's Avatar
After seeing Johns video of oil pressure drop on launch, I decided to install the baffles.
Spent the day fabbing brackets for a motor support, so I can lower the K member, drop the pan and install the Improved Racing Trap door baffles.
Bolted to the heads and have pads welded on them so they can set on the frame rails.
k member dropped and pan slipped out.
Comparison
Installed in to pan
All buttoned up.
Old Oct 1, 2012 | 09:32 AM
  #311
studderin's Avatar
nice work on the temp mounts.
That improved baffle fits really good. The front touches the pan a little perfect to seal it up so it stops oil from pouring out into the front on heavy braking. The moroso has a long over hang baffle on the lower front area, over the rear deep sump, that dose the same thing, maybe better but the pickup is in the back behind the tray door farther way so it need to be better.
The trap doors seals good to, better them my moroso one dose. If anything the rear baffle up the back of my moroso is fit with about a .08 gap, and welded in a few spots for the corners are still open. On final wash I noticed the oil went right thu the open corners of the baffle up the back of the pan pretty easy. Like you count 1-2-3 and its pouring thu the open corners and over the back of the pan out, faster then the baffle is keeping oil in the pan tipping it back. Next time I have the pan off I'm gona weld them up fully.
Old Oct 28, 2012 | 04:25 AM
  #312
Justinktm's Avatar
i read the whole thread i love it keep it coming !!
Old Nov 4, 2012 | 04:05 PM
  #313
Heyfred's Avatar
More parts came in.
Wideband:
3rd member case. Saving for pinion support, spool and yoke. Having a second third member will be nice. If I have to do a gear change, in and out quickly.
Gear set:
Wired in second OB2 port:
EFI Live:
Old Nov 9, 2012 | 07:30 PM
  #314
Heyfred's Avatar
Second OBD2 port is wired in. Bought a fog light switch, wired it in so I can turn EFI Live on and off for data logging with the fog light switch.
Old Jul 9, 2013 | 06:23 PM
  #315
Heyfred's Avatar
Just finished up a rear gear change. Went from 4.71 to 3.89, now to 4.30.
Also have the car set up to tune with EFI live
Made some tooling to hold the case and a spanner wrench.
This is my first time setting up a 9" and it is quiet as church mouse.
With this gear set, I am shooting for 11.50 because I don't have the roll bar installed.
Old Jul 9, 2013 | 09:17 PM
  #316
JRracing's Avatar
Very nice work. 1sc's are pretty cool.
Old Nov 11, 2013 | 06:04 PM
  #317
NVUSZ28's Avatar
I've been waiting for when you were bringing this car back to life!
Old Nov 11, 2013 | 10:07 PM
  #318
Heyfred's Avatar
The car is ready for the strip. 4.30 gear set has been installed.
Wife just took the car on 400 mile round trip, no issues and averaged 23 mpg on the freeway.
Keith
Old Nov 11, 2013 | 10:11 PM
  #319
stangtrader's Avatar
Good to hear your still plugging away at it Keith. Were gonna have to meet up at Pacific next summer.got my little fox in the 10s last month
Old Nov 11, 2013 | 10:22 PM
  #320
jsteele90's Avatar
this build is awesome! keep up the great work
