1SC stripper build
My car came with the ground effects from the factory. It is the RPO code: Y3F sport appearance package. It looks like a V6 car, but its a Z/28, i have seen a few SS's on here with the same package.
Here is the finished product so far.
My next project in the works for a fellow member.
One of Erics, MWC rearends with drag bar.
From Finishline Transmission
Level 6 trans.
Time to get the flexplate ordered.
Once trans is installed, get tune and go have some fun.
Upgraded the flexplate to billet aluminum.
Once trans install is done, get aligned front, rear and tuned.
I think this project is then completed and time to think of what to build next.
Ready to install the new flexplate and FLT trans, ran into some bolt issues when using an aluminum flexplate. New bolts are ordered.
Convertor installed in trans, test fit flexplate to convertor.
Keith
Have an issue to figure out, tach,temp and fuel gauge sweep when the key is turned on and then do no function once car is running
Need to get to tune and alignment.
