Drag Racing Tech
1SC stripper build
Old Apr 30, 2011 | 12:00 PM
  #121
Chubbz155's Avatar
Keith that car sounds amazing!!! Glad to see that your car is running and moving!!!
Old May 4, 2011 | 12:05 AM
  #122
S10Northwest's Avatar
Keith you've come a long ways on this, I can remember when you got this thing....your work is good and I know the reason why! lol enjoy it dude Ill check back on it.....I may want your help/advice on a an upgrade on my Sonoma....Larry
Old May 5, 2011 | 09:27 PM
  #123
Heyfred's Avatar
The SLP loudmouth was to loud and was going to get me in trouble. So I made myself a homebrew catback using Magnaflow mufflers.
Wanted to keep the Z28 style tips so I had to make them fit. Make them round.
Cut the so called resinator out and installed a straight section.
Cut the necked down 3" pipe off the merge collector and added a constant 3" piece.
Fitting the mufflers with 2.5" ID.
Finished product and this thing sounds good.
I need to get some 3/8" stainless rod. Weld hanger brackets on to the mufflers, then paint the mufflers black.
Old May 6, 2011 | 08:05 PM
  #124
Heyfred's Avatar
Exhaust is finished.
Pouring down rain no test drives today.
Now, time to save for a forged short block.
Old May 7, 2011 | 03:52 PM
  #125
Heyfred's Avatar
http://www.youtube.com/watch?v=PRBnU...yer_detailpage
Old May 9, 2011 | 07:58 PM
  #126
wws699's Avatar
That sounds good Keith Looks good too...
I'm predicting it will run an 11.43 @ 119 with a 1.52 60ft if it goes faster I'll buy drinks
Old May 9, 2011 | 10:03 PM
  #127
studderin's Avatar
sounds really smooth
Old May 9, 2011 | 10:32 PM
  #128
JRracing's Avatar
Sounds great. And looks good to.
Old May 16, 2011 | 02:27 PM
  #129
Heyfred's Avatar
Took the car out for a shake down, city and freeway driving. No overheating, oil leaks, transmission was warm after some stop and go traffic driving.
Ordered a cooler for the trans.
Overall, the car drives like a dream.
With 4.71 gears, in OD, the car spins 2800 down the freeway.
Once the cooler is installed, off to strip to what she will do.
AIR removed:
Old May 18, 2011 | 11:15 AM
  #130
Heyfred's Avatar
To help with cooling the trans, I upgraded the radiator to this and it should be here by the end of the week.
http://www.summitracing.com/parts/GRI-6-598AE-JAX/
Here is the trans cooler I will be using.
http://www.summitracing.com/parts/DER-51606/
Old May 18, 2011 | 12:15 PM
  #131
studderin's Avatar
Looks like they changed that front tire spec? I think is the closest now, a little wider?
http://www.mandhtires.com/store.php?...on=show_detail
If you get a chance can get you a wight of that front and rear wheel/tire setup?
Old May 18, 2011 | 12:33 PM
  #132
Heyfred's Avatar
Will do
Old May 18, 2011 | 11:39 PM
  #133
Heyfred's Avatar
Rear tire and wheel = 46 lbs.
Front tire and wheel = 37 lbs.
Old May 19, 2011 | 01:08 AM
  #134
studderin's Avatar
thanks, I added that info to the weight reduction sticky
I was confused on the front tire size, I think in post 34 you have the wrong link.
That wheel look and stance is so nice. What are you gona do next? Did you have ant dyno numbers?
Old May 19, 2011 | 01:39 PM
  #135
Heyfred's Avatar
Went back and corrected.
Did you have for dyno numbers?
RWHP=397
RWTQ= 376
93 octane fuel
Save for 4.125 bore, short stroke, all forged internal motor.
Old May 24, 2011 | 03:21 PM
  #136
Heyfred's Avatar
New radiator and trans cooler came in.
While waiting for them to arrive, I was able to build part of the trans cooler ram air system. Still waiting on parts to complete. I should be able to drive in stop and go traffic with out any worries of the tranny getting hot.
Duct under front bumper cover for tranny ram air.
Top view, looking behind front bumper cover.
Shroud, between radiator and front bumper cover.
I will have one more cold air intake line to the trans cooler with a fan hooked to a temp sensor that will turn on when oil temps rise in the trans.
Old May 24, 2011 | 03:51 PM
  #137
djfury05's Avatar
pretty sweet lil' trans cooler ram air setup there.. should help without a doubt
Old May 24, 2011 | 09:30 PM
  #138
Heyfred's Avatar
Went to install the radiator, will not fit correctly. To many changes to make it work and not worth it to me. Going to have to send it back.
Update
The radiator was suppose to be 2.5" wide, the one I received is 3" wide. So, I am going to call tomorrow to see if an error was made and the wrong radiator was sent.
Old May 27, 2011 | 09:48 PM
  #139
Heyfred's Avatar
Sent the radiator back. Called the vendor to verify it was the correct one. It was, but it was not direct bolt in as stated, so I sent it back. Ordered a Ron Davis and was assured it was direct fit. Will be here in approximatly 2 weeks.
So, I have been mounting the trans cooler. Everything should be done by the time the new radiator shows up.
Looking in from the drivers side.
Looking in from the passenger side.
Looking up from the bottom.
Old May 31, 2011 | 08:26 AM
  #140
Steve Gunn's Avatar
mmmmmmmm.....
black strippers.
