Rear Cover Hitting Upper PHB support
I installed my TA pivot plates today. I also re adjusted the pinion angle on the car but had an issue. My moser's rear cover fill plug hits the upper panhard bar support. I'm either going to have to cut a piece of the support off or by the relocation kit. I'd like to notch the support slightly to save the 200 the relocation kit costs but I'm not sure if that will mess with the structural integrity. Would it be safe for me to cut a piece of it off?
Also if I purchase an on car adjustable PHB would I be able to center the rear if I have LCAs with the poly bushings? Would this cause binding of the rear if I tried to adjust it using an adj phb?
do you know if it would be safe to notch the upper phb support?
yea i lowered the rear of my car & had to adjust the phb & lca's to get my wheels centered etc. no problems. I don't know about moving the mount. if done right it could be made really strong. doesn't someone make a phb that has a crook in it?
i think your talking about the bmr and umi phb relocation kits. they remove the top support and replace it with a tubular piece that mounts the phb lower. that kit is around $200. im thinking that kit would solve my problem as the top support piece that im having with would be replaced. but i could save that money by cutting a groove in the support. i just want to make sure that cytting it wouldnt cause any issues.
I have heard that for drag racing this will be fine, but road course racing this will cause stress on pass side mount area. I am welding a new sump in my tank. While I have the tank out, I am going to reinforce the area by connecting the two sides higher in the chassis so I can drop mine as well.
