Tip, Lightweight Battery on the cheap
But there's just no way that thing is going to have enough juice the start
the car with an extra 12-15ft of 2ga wire (plus the round trip though the frame for ground) in the mix.
However, moving the battery to the back is a great mod in itself.
It should be fine with a EWP. I wouldn't turn the pump on till the car is on though. I would wire it to get 12v key on. Not a source that has 12v key cranking. I would also put in a bypass toggle switch so you can manuly turn it off if the car is going to be sitting with the key on....ie loading a tune.
