Drag Racing Tech
Tip, Lightweight Battery on the cheap
Old Feb 15, 2009 | 01:58 PM
  #41
Demonicbird00's Avatar
i use to have the little race battery, but after i got an ewp the battery couldnt hold a charge the remote mounted pump was too much on the battery, so i had to get a normal size battery
Old Feb 15, 2009 | 02:21 PM
  #42
James Montigny's Avatar
Originally Posted by dlove
Why? Let me guess the hole
omg that MUST mean the rest of the car is ALL cut up.
Just giving you a hard time man, the screws holding those terminals on look funny at first glance.
Old Feb 15, 2009 | 05:07 PM
  #43
dlove's Avatar
Old Feb 15, 2009 | 06:49 PM
  #44
kmracer's Avatar
but the advantage with an odessey is that when it DOES die, you just charge it back up, and its one 130 or so for a 680? the thing will last for 8+ years. i used to sell them all the time at the parts store i worked at. they're perfect for a drag car that sits for long periods, as long as the batt is left unplugged it'll hold a charge for over a year.
what brand is the other one?
none the less, it does sound like a great deal.
Old Feb 16, 2009 | 12:07 AM
  #45
fly pantera's Avatar
I have had my etx14 in the z for over 6 months so thats all the winter,but I live in texas.thank you dlove after reading your thread I decided to get one,if it failed I could return it back to oreillys free of charged,win win situation for me.
Old Feb 26, 2009 | 05:09 AM
  #46
jetlag's Avatar
Thanks for the tip... I'm going to go to Advance and see what they got!
I bet I save at least 20lbs replacing that pig of a redtop Optima...ha
Old Feb 26, 2009 | 06:00 AM
  #47
joelster's Avatar
You'll probably save more than that. My 2 Z's stock batteries were 35 and 37 lbs apiece. Optimas are generally heavier than the stock batteries.
Old Feb 27, 2009 | 12:09 AM
  #48
Gunnar's Avatar
Moderator
Like Derek said I've got this battery in my daily driven car. Even with snow piled up on it and the temps in the negative she still started up every single time with no issue.
Old Feb 27, 2009 | 02:16 AM
  #49
jetlag's Avatar
So I can't find one at Advance, does it have another name?
Old Feb 27, 2009 | 07:44 AM
  #50
slow trap's Avatar
i just called my buddy at the local advance and told him i was looking for a battery for my car and told i was looking for an etx16 and he started laughing and said it was for a seadoo so those batteries are aparently designed for a jetski. may be in a different spot than the car batteries are. you'll probably need to bring in a core also (regular ol' battery may work)
Old Feb 27, 2009 | 06:31 PM
  #51
Well ... that's because they are.
Originally Posted by http://www.batterymart.com/p-Big-Crank-ETX16-Battery.html
Premium quality absorbed glass mat technology (AGM) is ideal for ATVs, motorcycles, personal watercraft, & snowmobiles. The Big Crank Power Sports AGM Battery was designed for more than performance; it was designed for the enthusiast.
I really think that the PC680 is a better deal.
http://www.batterymart.com/p-odyssey-pc680-battery.html
220 CCA
680 Cranking Amps for 5 Seconds
24 Minute Reserve Capacity
Old Feb 28, 2009 | 09:59 AM
  #52
slow trap's Avatar
i'm thinking about some kind of lightweight battery but still undecided. was thinking of getting one and putting it in only when i race my car . also thought about buying some lightweight carpet for race day only. both are a very good return for no more than you hace to spend.
anybody use that odyssey 680 or any of the braille batteries in cooler weather ?
Old Feb 28, 2009 | 11:10 AM
  #53
studderin's Avatar
Ive drianed my 680 15-20 times over NY winter storing the car, dynoing the car, leaving a door open..... Put the jumper box on it and it holds the re charge fine, had it for 3 years now.
When its under 30 out over 10* and the cars been sitting more then a week over winter I can normally start it with the big cam now. I get in close the door fast, prime the FP. key off, wait 10-20 secs with nothing on. Clutch in and crank it, I only have about 2-4 secs of cranking power, but unless its realy cold it starts.
Old Feb 28, 2009 | 11:18 AM
  #54
99_Z28's Avatar
I went to advanced today and gave him the part # he said nope theres nothing in the computer....im like ok, and take a walk around. Sure enough it was sitting right on the shelf for $70. My question is how do you mount your side post connectors to it?
AA employees
Old Mar 8, 2009 | 03:16 PM
  #55
99_Z28's Avatar
Hey guys I picked up a ETX16L, its 18lbs lighter than the stock Bosch battery and it whips the motor over just fine. It only took 10 minutes to swap out, I used the hardware that came with it and used the stock connectors with a washer. Beats the 4+hrs it took to take out the passanger side air bag for 14lbs...
Old Mar 8, 2009 | 11:26 PM
  #56
studderin's Avatar
wow thats realllllly fast
Old Mar 9, 2009 | 12:08 AM
  #57
JRracing's Avatar
Originally Posted by a98ws6
JRacing, what model battery is that? It may be $150 but so is a Optima and it still weighs less, so not really a down side. Clean install!
I'm not sure on the model #. i'd have to go look in jegs but it is the 15lbs version. It starts my car fine as long as it is fully charged. And it has 2ga wire all the way to the starter.
Old Mar 9, 2009 | 12:26 AM
  #58
RaggedRides's Avatar
Awesome trick. I wish I had known about this back when I bought a new battery. Maybe I'll put mine in the Firebird when we get the LT1 swapped in and cop me one of those bad boys. Been on a weight reduction kick lately and that's a good chunk.
Appreciate the heads up.
Old Mar 9, 2009 | 12:42 AM
  #59
silverz28camaro's Avatar
I have a ytx-20lbs in the back of my car, daily driver with 11.0 compression. Only problem is slow ish cranking under 32 degrees.
Old Mar 16, 2009 | 10:17 PM
  #60
383lt1impala's Avatar
What's the brand of battery I typed the part number on advances site but nothing came up.
