Drag Racing Tech
Cam only, winter upgrades. Bitch in on a diet
Old 06-29-2009, 03:52 PM
  #161
BigKap94z's Avatar
Looks great John, god damn i wish my car was 3360 race weight!!
Old 06-30-2009, 02:50 AM
  #162
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
I think the tires are probably your main issue. If you could get some nice 28x10.5 mt bias ply tires on there I bet you wouldn't have the spin / bog issue. How much do you weigh? I'm interested to see the weight of the car.
Old 06-30-2009, 02:01 PM
  #163
studderin's Avatar
look 1 and 2 post about you.
I have that size etdrags already, I like racing on my everyday DR too
thanks kyle
Old 07-03-2009, 09:11 AM
  #164
jp74's Avatar
WOW!!!! It is looking great John. Can't wait to see your times with the drag wheels
Old 07-04-2009, 07:44 AM
  #165
studderin's Avatar
done
I thought it should go faster then this, this is the order of the clock. I gotta check but I think thats my 1st, with I wasn't happy with. It yanked the wheels and I turned a little bit. So I pullled 2nd short at like 6K? (shiftlite is 6600) then pulled every gear early (6k?) But that was the feaster run? If so I need to lower the shift light and see if if it picks up. I'll check my dyno but I think 6600 was peak power. The other runs were dead on shift hitting gears. Biggest wheelie was the 3rd run witch was the slowest 1.599, I'll get the vid, it was 8inchs maybe a foot, but for like 8-10 feet and bounced back up. So tightened the front shocks form 0 to 2. It helped that it wasn't as big, hoping the car went forword, but it didnt really show up. The I wanted to get some wheel speed and try to get the slicks to spin 1-3 times. So went form 15 to 16.5 psi. another (1.556) The car run the same numbers? I think the better 60's should have showed up in the et's more.
anyone have any ideas??
DS2's -43 psi
28x10.5x15S 15 (16.5 last pass)
2step @ 6500 every pass (maybe bogging, tring not to dump the clutch tho)
Old 07-04-2009, 09:15 AM
  #166
95 Z28's Avatar
Nice times. Once we get some decent air you'll get 10s.
Love what you've done with the car
Old 07-04-2009, 11:24 AM
  #167
98blueSScamaro's Avatar
Originally Posted by studderin
done
DS2's -43 psi
I Ran into the same thing last time out i always shift at 6700 but one round i shifted it at 6400 and i mph 124 ET was a 11.55 with a crap 1.70 60 foot. And yes tire spin helps alot.
Here is a vid of how bad my car is bogging off the line and this was a 6200 rpm hit http://www.youtube.com/watch?v=p4K3z...er_profilepage
Old 07-04-2009, 11:18 PM
  #168
Mean87SS's Avatar
whta kind of rear sway bar do you run?
Old 07-04-2009, 11:31 PM
  #169
studderin's Avatar
the 1 inch 4140 spohn. I think a rod end BMR would be better, but I drive then on a street all week. I'm gona look at the vids and see how the sway bar is, so thats its not just yanking a tire but doing wheelies
Old 07-05-2009, 07:24 AM
  #170
Race your car!
JL ws-6's Avatar
You could always put an airbag in the right rear spring and ptu a little air in it to help the swaybar if the car is rolling over and you don't want to put a drag type bar on the car.
Looks like it's getting there though, good job!
Old 09-23-2009, 08:15 PM
  #171
02Z28's Avatar
Nice write-up... You do good work!
Old 09-27-2009, 10:45 AM
  #172
studderin's Avatar
thanks, I need to link some current stuff here.
Old 10-04-2009, 03:31 AM
  #173
BIG_T's Avatar
very nice detailed build thread
Old 10-11-2009, 11:15 PM
  #174
studderin's Avatar
some updates
Put a camara in the car, made a cool video
https://ls1tech.com/forums/manual-tr...autos-gay.html
tested a BBK85 and a FAST92 on the car. some good info in here.
https://ls1tech.com/forums/generatio...vs-fast92.html
car was not lauching stairt, added a spool last week. More predicable then the truetrac for a fast M6 car
https://ls1tech.com/forums/drag-raci...-truecrap.html
went some 11.20s on the stock rims, and DR on the back. Got a new best 1.599 and a 1.598 60's on that wheel setup.
On the way home driving slow the stock DIY adjustab;e master broke the arm. Did a new setup better with a bolt shank. posted some pics, and wer the stock in hollow inside
https://ls1tech.com/forums/manual-tr...r-writeup.html
Today got ran some 10.8s, on the drag wheels... 10.84 @127 was the best
https://ls1tech.com/forums/drag-raci...2-127-5-a.html
Old 10-28-2009, 05:13 PM
  #175
studderin's Avatar
update 10.66 best now
https://ls1tech.com/forums/drag-raci...0-6-128-a.html
edit,--- for the right link now
Old 11-08-2009, 09:54 PM
  #176
BIG_T's Avatar
congrats on the new personal best! just curious did u use any adhesive when u put in the speed inc carpet? i hear mixed reviews on their carpet so im just curious thinking of getting it myself
Old 11-08-2009, 09:55 PM
  #177
studderin's Avatar
thanks,
No I just put the carpet in, kept the mattering under it still it comes with. But its out right now still form when I got the car in lightweight mode. This winter I'm gona have that seam sew'd (sp?) so its one piece up over the top. DId you hear anything bad? I htink its great, alot better then the stock after stripping it all. it only safed like 7-8#s and was still heavy as **** and loud. Speed inc is still loud, but alot lighter.
All I had this year, I put some duct tape insideout loops behind it to hold the top of the rear seat part up. Its worked ok for a while, with the sided tucked under the side pannles. But when I'd put a blanket down and put the slicks in the car. It would pull it away a little. I'd put one slicks right behind the driver seat, had a way to get it down in there past the dome light, and fit it tight to the hoop., And a skinny on the other side. The other slick on top of the gas tank, and other skinny in the Ttop well. with the floorjack, and other tools. I have that piece of the light gray Oritze, now for the top the speed inc carpet is short. But not sure if I will get darg grey, or cut that part off my stock carprt.
took out a little more weight this weekend.
With the 20TL mufflar, I dont need the whole stock sized heat sheild. So I cut a lot off ot it, and bend a little 1/4 lip on the outside. Its stiffer then stock now, fits great dosn;t rattle or anything. The middle is maybe 7x20 just the size of the mufflar, with 2 strips running to the bottme of the Ttop well for thouse 2 bolts. And 2 section on the side to thosue bolts, the over the axle side is maybe 3inch wide. And cut way down the other hear sheild for the over axle part. Not a lot of weight but its half the weight still covers all the plasitc tank, and alot more room back there now. And took off the panhard rod brace, that with the bolts was maybe 5-6#s. I already took the heats sheilds off for the Ypipe. Just leave that one that hold for the clutch line.
if I'm gona keep the S60 still, Im gona make transmoutn lower shock mount tabs. Over the stock studs style I use now. And I'd like to make the with 2-3 places, becuse the car is lowerd, and the bigger tires. So I can let the rear end hang and not have the cut coils unseat. (the summit shocks are longer not too) But with the BMR weld on LCA reloc brackets, and it having the stock spring, and everything else brakets. Theres some extra metal than can be removed if I want to put the time in. But I'd still like to just order a 4130 fab9 housing kit from quatermax and make my own this winter. Same for a TA, and make a alum trans mount with the TA mount like my BMR but lighter.
Old 11-10-2009, 08:22 PM
  #178
studderin's Avatar
I painted the back of the kirkeys with the black (dark gray) hammer paint. Looks alot better then the raw alum I'll get some pics up later with the covers on, need a 2nd coat. I rolled it, and some of the "hammer" finish marks look open. Make sure you wipe the seats down good, they have some oils and stuff from the brake, and bead roller making them. I was going to have them powder coated but they need to be acid washed and alot of prep, and not sure if it would have any problems. So just painted them.
Old 11-12-2009, 02:19 AM
  #179
studderin's Avatar
I cut a little off the back of the seat plates, I'm never gona use thouse holes and this makes them look a little cleaner not sticking past the seat. Painted them with a can of the same hammer black but in a spray can, and it looks black? weird? Seats are the same can I used on the rollbar, only painted were the covers don't cover. Did around the inside holes for the belts too. Should be cleaner then the raw alum.
looks good so far
Old 11-12-2009, 08:23 AM
  #180
bgblockelcamino's Avatar
looking good. come a long ways with your car
Quick Reply: Cam only, winter upgrades. Bitch in on a diet
