Drag Racing Tech
Competition Engineering Rear Drag Shocks?
Old Mar 9, 2009 | 04:10 PM
913MOTOR's Avatar
I wonder if CE is making them and summit is repackaging them.
The fullsize guys that lower trucks use a summit shock that is a Doestech which is about twice as much in price but they are packaged in a summit box.
Old Mar 10, 2009 | 01:07 AM
evilbeef54's Avatar
http://store.summitracing.com/partde...5&autoview=sku
here ya go, on sale right now $23 a piece
Old Mar 10, 2009 | 11:49 AM
not7fifteen's Avatar
Those summit ones don't say they will fit a late model F-body... Is it wrong? These have the same specs as the Comp Eng. ones but they say for 83-88 firebird only or 67-68 wtih multileaf only... ?
http://store.summitracing.com/partde...58+4294781243+
http://store.summitracing.com/partde...8+&appfilter=1
Old Mar 10, 2009 | 01:15 PM
patriotformula's Avatar
I cross checked with the Comp Engineering shocks and these have the same applications as the Comp Eng. 2700 shocks. I looked at the install guide and even the settings are labeled the same on these vs. my comp engineering shocks... Looks like the cheap just got cheaper fellas! have at it!
http://store.summitracing.com/partde...=1#Application
Old Mar 10, 2009 | 08:05 PM
Which are the correct front drag shocks?
Old Mar 10, 2009 | 11:13 PM
^they don't carry fronts for fourth gens... nor does comp (as far as I know). For the fronts your choices are still QA1, strange, afco, kyb, etc...
Old Mar 10, 2009 | 11:29 PM
cool thanks for the info!
Only thing that sucks about them is by the instructions you can only adjust when the shock is off the car correct?
Also for comparisons sake about what type of ratio would the stock shocks be in terms of like 50/50 or 40/60 and such?
Old Mar 11, 2009 | 01:26 PM
I'm not sure what the stock shocks have for a setting... Either way, yours are most likely very worn and have different characteristics anyways.
That is the one downfall of the comp shocks... However, just set them on 50/50 (everyone has the best results with that) and leave them... You'll notice a good improvement for sure.
Old Mar 13, 2009 | 02:42 PM
bracketracerZ28's Avatar
Originally Posted by omcar
get QA1 12 way adjustables
I sure wish we could get the DA you have in your signature....that's awesome
Old Mar 13, 2009 | 08:25 PM
kp's Avatar
kp
CE shocks in the rear and single adjustable Strange fronts, 1.30-1.28 60 foot on these passes, 1.23 60' best:
http://lsx.streetfire.net/video/1475...e2017b4207.htm
Old Mar 13, 2009 | 08:34 PM
FlashLCD33's Avatar
I got the Summits thursday and installed em. They sure do fit a 4th gen, IDK why it's not listed!
Old Mar 13, 2009 | 11:18 PM
  #32
bluehawk2's Avatar
Is that the correct shocks for a Firehawk listed in the first post? I know my car is a little lower than most from the factory......................Part # for the CE rear shocks??
Old Mar 17, 2009 | 02:32 PM
  #33
STANG KILLA SS 2's Avatar
which one is it guys? im fixin to order but yall posted links to two different shocks the 7600, and the 7700....
so which is correct? 7600, or 7700?
Old Mar 17, 2009 | 02:53 PM
  #34
Skinny's Avatar
The 7700 is correct. (note the extended and collapsed length)
Old Mar 17, 2009 | 10:51 PM
  #35
yep... 7700 is correct. 7600 are front style shocks (ratios anyways).
Old Mar 21, 2009 | 10:07 AM
  #36
RENE'S RAGE's Avatar
What springs are you running in the back and fronts.
Old Mar 23, 2009 | 11:17 AM
  #37
BigKap94z's Avatar
Originally Posted by Magnet
Can someone get a link to the Summit ones? I don't want to order the wrong ones..
I have the summit G7700 shocks sitting here for my car, they say doetsch tech DT 1105 right on the shock. I hope they work well.
Old Mar 23, 2009 | 03:53 PM
  #38
913MOTOR's Avatar
Yea, I got mine in, doesch tech is a good company and many have had good success with them on lowered trucks and they are the preferred shock.
Old Mar 23, 2009 | 05:09 PM
  #39
gonzo4886's Avatar
I just got mine in . What setting is 50/50? XF, F, R
Old Mar 23, 2009 | 05:46 PM
  #40
BigKap94z's Avatar
I believe F(firm) is the 50/50 setting.
