Drag Racing Tech
Competition Engineering Rear Drag Shocks?
Old Apr 2, 2009 | 11:42 PM
  #41
sscamaro1384's Avatar
how do the summit or the competition engineering rears ride on the street? Anyone running them with lowering springs? They say for drag use only but just wanna make sure they re cool for the street.
Old Apr 3, 2009 | 07:18 AM
  #42
105's Avatar
105
I've only riden on mine a couple times so far and they feel ok. I'm guessing they're just gonna make the rear a little more jumpy when you go over bumps and stuff.
Old Apr 3, 2009 | 08:18 AM
  #43
BigKap94z's Avatar
I run mine in the Firm (50/50) setting, they are defn more stiff on the street. The ride is fine though. I am running them with stock rear springs that have been cut, and Strange SA's up front.
Old Apr 3, 2009 | 11:56 AM
  #44
BOLO's Avatar
Originally Posted by gonzo4886
I just got mine in . What setting is 50/50? XF, F, R
FYI 50/50(R), 60/40(F), 70/30(XF). A 50/50 setting would be like a normal(stock) setting.
Old Apr 3, 2009 | 02:30 PM
  #45
not7fifteen's Avatar
So the point of these shocks is only to be able to stiffen from the stock rate if the stock setting is like a 50/50 as you said? I figured the point would be to soften the rear for launching, is my theory backward? I'm a drag suspension newb still...
Old Apr 7, 2009 | 12:15 AM
  #46
rsodeputy61's Avatar
Originally Posted by RENE'S RAGE
What springs are you running in the back and fronts.
x2 what springs are u guys running with these? how will they hold up with a lowered rear spring? think i'm going to run a strange coilover up front, but cant decide on the rear setup...
Old Apr 7, 2009 | 09:53 AM
  #47
gonzo4886's Avatar
I called summit and asked what the setting are their shocks
R 70/30
F 50/50
XF 40/60
I also looked on competition engineering website for their settings
R 50/50
F 40/60
XF 30/70
Old Apr 7, 2009 | 01:37 PM
  #48
913MOTOR's Avatar
How do you tell where the notch on the summit shocks are? You can turn them one way and they keep clicking but dont click in the opposite direction. You would think they would click three times and stop for the different settings but they just keep going.
Old Apr 7, 2009 | 05:45 PM
  #49
keith_AE2010's Avatar
In the directions it says compress the shock all the way, turn it until it clicks, then just turn it until the little mark matches up with the setting you want.
Old Apr 10, 2009 | 06:27 PM
  #50
can anyone tell me how these perform with lowering springs???
Old Apr 13, 2009 | 01:37 PM
  #51
anyone???
Old Dec 3, 2009 | 08:08 PM
  #52
Shownomercy's Avatar
Man-Crush Warning
I got a pair of the G7700 summit shocks and they both are fully collapsed... I clicked the 50/50 setting.. but are they supposed to extend? Or do I pull them out and then install?
Old Dec 3, 2009 | 10:51 PM
  #53
ryarbrough's Avatar
Pull them out and install.... The setting is just a dampening adjustment... It does not determine the length or throw of the shock
Old Dec 16, 2009 | 11:18 PM
  #54
gjohnsonws6's Avatar
So are the CE shocks made by Doetsch tech?Can anyone look at thier CE shocks and see if there is a stamp on them? Are the summit shocks any good?
Old Dec 21, 2009 | 09:51 PM
  #55
01FbTaWs6's Avatar
i love my CE shocks. Cant beat them for the money!
Old Dec 27, 2009 | 01:44 PM
  #56
T/A KID's Avatar
Sweet looks like I am going to get some of these shocks as well, probably throw on a lowering spring since my car looks like a 4X4. Plan on running the Strange single adjustable coil over on the fronts.
Old Dec 31, 2009 | 12:44 PM
  #57
Fifedogg's Avatar
I just ordered me a pair. Hopefully they work good on a lowered car. I already have a 1.59 60' on my sagging stock shocks.
Old Dec 31, 2009 | 01:25 PM
  #58
AChotrod's Avatar
I just put Strange DAs up front with 300# springs, and the CE 3ways out back. The rear rides alot stiffer than stock but tolerable on the 50/50 setting Im also running stock rear springs.
Old Jan 2, 2010 | 08:50 AM
  #59
ski23's Avatar
Im currently running Strange singles and 275lb springs upfront with Summit socks with 1.5 coils cut off the rear springs. Shock set at 50/50 and ride is ok for me. It does hit hard on the big bumps but, thats the trade off being lowered some I guess. I think im gonna put stock rear springs on and only take 1/2 a coil off and do the heater hose mod.
Old Jan 2, 2010 | 11:10 AM
  #60
a98ws6's Avatar
How does it sit with 1.5 coild cut off? Do the Summit shocks look like a stock shock but painted white?
