Drag Racing Tech
midplate pics
Old Mar 13, 2009 | 09:23 AM
pro382d's Avatar
Default midplate pics
just as the title says, im looking for midplate pics if you have em'. or at least an exp. of how you mounted yours.
Old Mar 13, 2009 | 10:50 PM
pro382d's Avatar
nobody on here runs a midplate?
Old Mar 14, 2009 | 03:11 AM
DanZ28's Avatar
Well, this isn't mine but it's close to what mine will look like.
Old Mar 14, 2009 | 01:16 PM
pro382d's Avatar
thanks, anybody else?
Old Mar 14, 2009 | 10:04 PM
ty_ty13's Avatar
7 Second Club
we ran 1 5/8 tube and bent it 2 times and welded it to each frame rail then welded nuts inside tubing and bolted it in.
Old Mar 14, 2009 | 10:06 PM
ty_ty13's Avatar
7 Second Club
Old Mar 16, 2009 | 09:03 AM
Steve Burger's Avatar
LS1TECH Sponsor
Check my car in the gallery section of our site. We sell a kit.
Old Mar 16, 2009 | 09:23 AM
Fireball's Avatar
heres a pic of mine
Old Mar 16, 2009 | 09:30 AM
ty_ty13's Avatar
7 Second Club
we needed all the header clearance we could get... thats why we did ours like we did.... we cut the "ears off our mid plate
Old Mar 16, 2009 | 03:05 PM
pro382d's Avatar
that last pic is what im looking for, but the other side is where my concern is, the fire wall comes out farther on that side and it looks like there wont be enough room for the plate.
Old Mar 16, 2009 | 04:33 PM
LS1TECH Sponsor
Here is a front and mid pic.
Old Mar 16, 2009 | 06:05 PM
1SlowFormula's Avatar
Steve that isn't working, you need ".w560h420.jpg" at the end of the URL for that image...
I fixed it in my quote and also put up this one from your car...
Old Mar 16, 2009 | 06:20 PM
pro382d's Avatar
thanks guys i see what some of you are doing now, and steve, i have seen your car at the drag expo before and even talked to you and had forgoten all about how you did your plate.
thanks for the pics guys, now its time to go bend some tubing and get it done.
Old Mar 16, 2009 | 07:05 PM
LS1TECH Sponsor
Thanks, Fixed the link.
Old Mar 17, 2009 | 09:31 AM
ty_ty13's Avatar
7 Second Club
see im not soo crazy after all... hell even burkhart mounts them like mine
just make sure you mount the motor and tranny as far back as you can to help with weight distribution..... the motor and tranny are the heaviest pieces so moving them back 1" helps TREMENDOUSLY
Old Mar 17, 2009 | 10:44 AM
Jon@Texas-Speed's Avatar
Here's a couple pics of my current project.
Old Mar 17, 2009 | 10:45 AM
ty_ty13's Avatar
7 Second Club
bigger pics please
Old Mar 17, 2009 | 12:02 PM
Ty and Steve, I assume you guys are running steel mid plates and welding them, if not how are you mounting them? I was thinking about running Alum motor an mid plates, but can't see a good way to mount Alum to the mid plate support you guys are using and have it hold well...
Old Mar 17, 2009 | 12:09 PM
ty_ty13's Avatar
7 Second Club
i used steel midplate and aluminum motor plate
Old Mar 17, 2009 | 03:13 PM
LS1TECH Sponsor
AM Motor and Steel mid. We weld a bracket into the hoop to bolt the mid plate to.
