Witch 16" DR hooks better??
http://i2.photobucket.com/albums/y11...n/IMG_2884.jpg
And looking to run a larger DR (27.5"- 28"). My drag only wheel setup is, gregweld/prostars are the 28x10.5 stiff ETdrags, and work great. But looking to run these most of the time this summer, not on long trips ect. But still hook ok at the track, and street. I know with the m6 there not goign to dead hook off the limiter.
Looks like there 2 close DR sizes
http://store.summitracing.com/compar...1&autoview=sku
Mickey Thompson 3794R
295/50-16 Or about 27.69x10x16
Minimum Recommended Rim Width (in): 8.00 in.
So they should be fine on stock 16x8s. But I'm turned off by how heavy they are listed at 33# a tire
Next is the:
M&H DR ROD08
275/55-16 or about 28.0x9x16
Minimum Recommended Rim Width (in): 9.00 in.
But I've seen them on stock snowflakes and they fit fine, the sidewall width is alot less the the MT sized safe for a 8inch rim. I'm gona call to find out there weights. But that seam to be in stock easily, the MT last I checked a few weeks ago were on there way
The both cost about the same price. Anyone running either DR on stock wheels? The MT sounds like a big *** tire, but alot of auto guys get some GREAT short times on them. But I havn't see that size yet. Not heard anything on the M&H? looking for any feedback, the search wasnt finding anything.
thanks
not sure how well a 295 will fit on an 8" rim, my 275s bubble pretty well on my 15x8 prostars
whats size MT are you running? I know some locals, with 3800-4400 stall autos running 11's getting low 1.5s on the smaller 26" 255/16 MT DR. Even seen bad2000z (seth) pull the front tires are few inches. I hate you auto guys.
The car has seen lower 60 but in in much better air though with with a 315 MT radial.
thanks, REDGAR
What wheels do you have the tires mounted on? If it's a 8" rim how are they fitting, and driving on the street. Do you have any pics of them.
Thats a great short time, your car is a auto?
Yes it is an auto. Beefed up Vette Doctors built trans with 3.90 or 4.10 gears, I forget we change them so much. QA1 single adjustables all the way around.
Ripped a couple of 1.39's today
just a update, I orded the Mand H right off there site after talking to them. (wanted to get the MT from summit to use the Atech price but they have been on back order sence last year) And that PN has been replaced with a slightly wider ROD18
I'll post up how these tires do. They look really nice so far.
https://ls1tech.com/forums/wheels-ti...x8-wheels.html
just some more info I was looking at that tires alot, and the simlar M&H. I just got M and H and they just updated them. Same size, 275/55/16 the old PN was ROD08 now its ROD18 but the section with is 10.4 over the older 9.8 or somthing smaller. But they have a 9.5 contact patch and a 28.0 over the MTs that are 27.5 The MT are heavier I seen listed at 33-35 a tire. These M and Hs are 29.5#.
thats new MT II tread looks alor better for the street then the older one. I'm intrusted in how long they last. These MandH have .200 tread depth, off the rim there were like 8.5 inside the beads relaxed, so there fine on the 16x8. Summit pushed the MT backorder again, cool jegs has them. I got might right from MandH
so far on my M&H best is a 1.61 yanking the tires for 1 sec. running a 11.38 in a m6 car. most are mid 1.6s. Im really happy with them.
